Linear Algebra Proof using Inverses
7 replies · 3K views
B18
Prove that if A, B, and C are square matrices and ABC = I, then B is invertible and B−1 = CA.
I think I have this figured out, just checking it. Heres what I got:
ABC=I
(ABC)B-1=IB-1
(B*B-1)AC=IB-1
I*AC=IB-1 Cancel I using left hand cancellation property
AC=B-1
Thus B-1=CA
Is every thing I've done here mathematically correct?
ABC=I
(ABC)B-1=IB-1
How do you know ##B## has an inverse to use? You are trying to prove that.
(B*B-1)AC=IB-1
And, even if you did, how did you get that step? Matrix multiplication isn't commutative.
Ok, yes I see what you're saying. I can't do the steps I did there. I know that B has to have an inverse because A,B, and Care square matrices and their product is the identity matrix.
Is this a correct path to go down on this proof?
We have ABC=I
(AB)C=I. Since (AB)C=I we know that (AB) and C are both invertible. Also this tells us that C=(AB)-1, and (AB)=C-1
You can also reorder the multiplication using
CABC = CI = C =IC
Implies CAB = I.
Same logic as in your last post should bring you to the solution you are looking for.
How does this look:
We have ABC=I
C(ABC)=CI
CABC=C
(CABC)A=CA
(CAB)CA=CA This implies that CAB=I
CA(BCA)=CA This implies that BCA=I
CAB=BCA
(CA)B=B(CA) Then B must be invertible
Therefore BCA=I
CA=B-1
Looks good to me. You hit all the important points.
I think you need to flesh out your argument with a few more details. Your steps may be correct, but if this is a homework problem you need to fill in some reasons.
B18 said:
How does this look:
We have ABC=I
C(ABC)=CI
CABC=C
(CABC)A=CA
Why do those imply those?
CAB=BCA
Why must B be invertible? That statement by itself doesn't imply it.
Therefore BCA=I
Why the "therefore" now? Didn't you already have BCA=I above?
CA=B-1
Like I said above, your statements may be true, but your teacher is going to want to know if you know why they are true.
