Linear algebra (trying to prepare for exam)
10 replies · 3K views
frasifrasi
Ok, here we go.
The question asks,
for matrix A =
1 1 3
3 0 1
2 2 6
, find a vector b such that Ax(x is a vector) = b has no solution.
I found the rref(a) =
1 0 1/3
0 1 8/3
0 0 0
Now to, answer the question,
I gues the equation has no solution if one of the rows has 000 = a nonzero value.
So, is it right to say b is a with a nonzero value on the third row?
Is there an alternate way without having to work with range -- we didn't do this in class ?
Well, you as you've said if b has a nonzero third component then you can't solve rref(A)x=b. Fine. But that doesn't mean you can't solve Ax=b. Now you have to 'undo' your row reduction operations on e.g. b=(0,0,1). Do the opposite row operations on that b to get a vector such that Ax=b doesn't have a solution.
?? Surely they mentioned in class that Ax= b has a solution if and only if b is in the range of A! In fact, that is the definition of "range". You seem to be wanting to do what so many students unfortunately want- to apply a formula without having to understand what you are doing!
Saying Ax= b, here, is the same as saying x+ y+ 3z= bx, 3x+ z= by, and 2x+ 2y+ 6z = b3 and you have shown, by row reducing the matrix, that that corresponds to x+ (2/3)z= 2bx- (1/3)b[sub[y[/sub], y+ (1/3)z)= (1/3)b- a, 0= c- 2a. Looking at the last row we see that has a solution if and only if c- 2a= 0 or c= 2a. It does not have a solution is c is not 2a.
No, it is not. For example, b= [1, 0, 2] has a nonzero value on the third row but Ax= b for this A and b is the same as x+ y+ 3z= 1, 3x+ z= 0, 2x+ 2y+ 6z= 2. From the second equation, z= -3x. Putting that into the first equation gives x+ y- 3x= -2x+ y= 1 or y= 2x+ 1. Putting that into the third equation, 2x+ 2(2x+ 1)+ 6(-x)= 2 which is true for all x- the xs cancel on the left.
It is true that an equation with the reduced matrix has no solution if there if the third component of b is non-zero. You should have carried the "b" values along with your row reduction to see what the right hand side should be for the original equation.
"that that corresponds to x+ (2/3)z= 2bx- (1/3)b[sub[y[/sub], y+ (1/3)z)= (1/3)b- a, 0= c- 2a. Looking at the last row we see that has a solution if and only if c- 2a= 0 or c= 2a. It does not have a solution is c is not 2a."
--> Can you please explain how you got that from the rref? I see x+ (2/3)z, but where does the 2bx come from...?
Oh ok, I understand. So, the augmented matrix had only numbers and b's on the right, where did the c and a variables come from?
This is the last thing I need to graps this. Thanks once again.
can halls or anyone pick up on my last question?
Thank you.
OK, I see. Just for closure.
Since it is only if b_z is not 2b_x,
would be one such vector, right?
Thanks!
