Linear Differential Equations, no x in p(x) or q(x)?
The discussion focuses on solving linear differential equations of the form y' + P(x)y = Q(x) when P(x) or Q(x) lacks the variable x. Specifically, the examples provided are y' - y = 4e^x and y' + 2xy = 4. The participants clarify that it is valid to define P(x) as -1 for the first equation and P(x) as 2x for the second, while Q(x) can be treated as a constant function, such as 4. The consensus is that constants can still be viewed as functions of x, as they yield the same output for any input.
  • Understanding of linear differential equations
  • Familiarity with integrating factors in differential equations
  • Knowledge of function notation and constant functions
  • Basic calculus concepts, particularly derivatives
  • Study the method of integrating factors in linear differential equations
  • Explore the implications of constant functions in differential equations
  • Learn about the existence and uniqueness theorem for differential equations
  • Investigate advanced techniques for solving non-homogeneous linear differential equations
Students and educators in mathematics, particularly those studying differential equations, as well as professionals in fields requiring mathematical modeling and analysis.
rygza
An integrating factor e^(integral p(x) ) can be used to solve Linear D.E. in form y' + P(x)y=Q(x), but what do i do when there is no x in P(x) or Q(x)?
for instance in these problems: #1)y' - y=4(e^x) #2)y'+2xy=4
Is it wrong to use P(x)= -1 for problem 1, and Q(x)=4 for problem 2?
This is what I've been using but I can't check if it's right (answer not in back of book).
1) p(x)=-1, q(x)=4e^x & 2) p(x)=2x and q(x)=4 ( Just because there's no x doesn't mean its not a function of x, or of whatever independent variable your working with; its just for every x value u'll get the same f(x), which is obv since its constant. you can view it as f(x)=4x^0, whatever x you use you'll get 4)
adriang said:
1) p(x)=-1, q(x)=4e^x & 2) p(x)=2x and q(x)=4 ( Just because there's no x doesn't mean its not a function of x, or of whatever independent variable your working with; its just for every x value u'll get the same f(x), which is obv since its constant.)
hmm i see. Thanks for the clarification
