How Do You Choose Initial Conditions for Coupled Linear Differential Equations?
Choosing initial conditions for coupled linear differential equations involves understanding the system's dynamics and ensuring the conditions reflect realistic scenarios. Initial conditions should be based on the physical context of the problem, such as equilibrium states or boundary conditions. It's important to consider the stability and behavior of the system when selecting values for x1(0) and x2(0). Sensible choices often stem from empirical data or theoretical predictions related to the system's application. Properly selected initial conditions can significantly influence the system's evolution and solution behavior.
sssspppp
Hi
can anyone tell me how I can chose/investigate some sensible initial condition for a coupled linear system of linear differential equations?
x*=Ax where (x1(0) x2(0))=(a,b)
Thank you
sssspppp said:
Hi
Thank you
Can you clarify what you're asking?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
