Linear independence with differentiable functions
6 replies · 2K views · last reply
kbrono
I don't this this is an overly complicated proof but it is one I have never seen or done before.
Let f be a polynomial with atleast two non-zero terms having different degrees. Prove that the set {f(x),xf'(x)} is linearly independent in P
Proof:
With out loss of generality we can take f1(x) = 1 and f2(x) then xf1'(x) = 0 and xf2'(x)= x. Thus we have the matrix A=[[1,x],[0,x]] and rref(A)=[[1,0],[0,1]] and is therefore linearly independent.
Uh, I don't really understand your proof... what are f1 and f2? And why is there no loss in generality in showing this??
I really don't see what this proof has to do with the theorem...:confused:
You might want to expand a general polynomial f(x) and x f'(x) in a suitable basis.
Sorry i use a weird notation, f_1(x) denotes the the first term in f(x) f_2(x) denotes second term in f(x).
im breaking down f(x) = 1+x and f'(x)=0 + 1 into a term by term format.
What I'm doing is setting up a matrix where the first like is f(x) and the second line is x(f'(x)) then using rref to show they are linearly independent. I say without loss of generality because we only need atleast 2 different terms with different degrees so it doesn't matter which two I pick.
Hope the clarify's what I am saying...
Looks like i forgot to add that {f(x),xf'(x)} is linearly independent
I could be way off mark but since we only need two different, doesn't it suffice to prove for just two different degrees?
Thank you
You've shown that 1+x and x (1+x)' are linearly independent, not that this is true of all polynomials.
ah, ok so i should expand for each term out to the nth?
If you mean "write down a general nth order polynomial," then yes.
