Linear Momentum to Angular Momentum
The problem involves a bullet striking a door and the subsequent calculation of the door's angular velocity after the impact. The context is within the subject area of linear and angular momentum in physics.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the relationship between linear momentum and angular momentum, questioning the validity of equating them directly. There are attempts to clarify the conservation principles involved and the need to consider angular momentum relative to the hinges of the door.
The discussion is exploring different interpretations of momentum conservation in this scenario. Some participants are providing guidance on calculating angular momentum and emphasizing the importance of considering the reference point (the hinges) when analyzing the problem.
There is a mention of the constraints imposed by the hinges on the door's motion, which affects the conservation of linear momentum. Participants are also questioning the assumptions about the angular momentum of the bullet relative to the hinges.
brad hars
A 10 g bullet traveling at 400 m/s strikes a 10 kg , 1.2-m-wide door at the edge opposite the hinge. The bullet embeds itself in the door, causing the door to swing open. What is the angular velocity of the door immediately after impact?
p[/B]= mv
L = Iω
For the bullet:
p = (0.010) * (400) = 4
For the door:
I = (1/3)(10.01)(1.2)^2 = 4.8048
Momentum is conserved.
p = Iω
4 = 4.8048 * ω
ω = 0.833
This seems right, and I've traced it over again and still seems right, but it's not and I can't seem to find out why.
brad hars said:
p = Iω
Here is your problem. You are setting linear momentum p equal to angular momentum Iω.
Well, yea. Because the bullet goes in the door and all that linear momentum p goes into angular momentum. I'm not sure what else I could do with it.
Try to calculate the angular momentum of the bullet. Angular momentum and linear momentum are two separate quantities.
Linear momentum is not conserved because the hinges prevent the door's center of mass from moving in a straight line. You have to set the angular momentum of the bullet (relative to the hinges) equal to the angular momentum of the door (also relative to the hinges). Keep apples with apples and oranges with oranges.
But doesn't the bullet have 0 angular momentum?
Not with respect to the hinges. ##\vec{L}=\vec r \times \vec p##.
  • · Replies 18 ·
17K
  • · Replies 45 ·
  • · Replies 62 ·
14K
