Is there a more accurate way to estimate sales quantities?
The discussion focuses on estimating sales quantities of matchboxes based on price, using the equation q = 16000 - 2500p for prices between 2 and 6. Participants analyze the maximum error margin of 1,000 units and seek to determine the price range that allows for an estimated quantity of 7,250 units. The conversation also addresses the calculation of the lowest value for E, which represents the maximum error in estimates, ultimately concluding that E should be 250. Additionally, the percentage error for each price point is calculated, indicating varying levels of accuracy in the sales estimates. The quality of the estimate is evaluated based on its intended use and potential alternatives.
help
homework. Am I thinking right? modular inequality
The number of matchboxes that will be sold in a month can be estimated according to
the price p of each box. The estimated quantity of boxes sold is related
with the price p according to the equation
q = 16000 - 2500p
when the price is between 2 and 6.
The company cannot sell with a price below 2 and greater than or equal to 6.
Note that q is just an estimate of the quantity sold. In normal scenarios, this
estimate has a maximum error of 1,000 units in relation to the actual quantity determined
r at the end of the month.
Determine the price range that should be used for the number of boxes sold
is equal to 7,250 units, within the maximum error margin of the survey.
So, I started this problem and I would like to be sure of what I did.
attached resolution attempt
help said:
Homework Statement:: homework. Am I thinking right? modular inequality
Relevant Equations:: The number of matchboxes that will be sold in a month can be estimated according to
the price p of each box. The estimated quantity of boxes sold is related with the price p according to the equation
q = 16000 - 2500p
Note that q is just an estimate of the quantity sold. In normal scenarios, this estimate has a maximum error of 1,000 units in relation to the actual quantity determined r at the end of the month. Determine the price range that should be used for the number of boxes sold is equal to 7,250 units, within the maximum error margin of the survey.
Hello @help . (Maybe use a better name)
:welcome:
Your solution:
It looks correct to me.
Hi, thanks for replying.
Letter Bb)
Over 6 months, several prices were tried. The following actual sales figures are observed, according to
with each price charged:
The company believes that a good estimate q of the quantity sold can be given by
Give the lowest value you can for E so that https://mathhelpforum.com/attachments/1587578280478-png.40117/ in all observations made
So, I would like to be sure of what I did.
pqrE
335003250250
3,234003570170
3,532503100150
430002890110
4,527502550200
5250025000
Something missing here, like a new formula for q?
So that what?
Sorry!
q = 5000 - 500p.
Give the lowest value you can for E so that |q - r | E in all observations made.
help said:
Sorry!
q = 5000 - 500p.
Then your work in post #3 looks correct, but what is your answer for the lowest value of E meeting the condition?
the lowest possible value for E would be zero correct?
to end the question has an item c...
c)
Calculate the percentage of error observed |q-r| in relation to an actual quantity sold each
month.
From there, your opinion on the quality of this estimate.
percentage error = E/r
what does your opinion mean about the quality of this estimate?
pqrE
335003250250
7,69%​
3,234003570170
4,76%​
3,532503100150
4,84%​
430002890110
3,81%​
4,527502550200
7,84%​
5250025000
0,00%​
No.
Your confusion comes from having used E in your table in a different way from the way it is used in the question.
Your table lists six values, so let's call these Ei, i=1..6.
The question is asking for the least value of another variable, E, such that |Ei|≤E for all i.
haruspex said:
No.
it's clearing up a little bit. I can leave | q-3000 | ≤500 because so 2500≤q≤3500. That is E = 500 ?
pqrr-q|r-q|
335003250-250250
3,234003570170170
3,532503100-150150
430002890-110110
4,527502550-200200
52500250000
pqrr-q|r-q|
335003250-250250
3,234003570170170
3,532503100-150150
430002890-110110
4,527502550-200200
52500250000
I don't understand how you get 500.
You have six values for |r-q|. What is the smallest number E such that none of the six values exceed E?
Oh ok I got it. It is a maximum error. then E = 250
Right.
Thanks!
c)
month.
pqrr-q|r-q|
335003250-250250
7,69%​
3,234003570170170
4,76%​
3,532503100-150150
4,84%​
430002890-110110
3,81%​
4,527502550-200200
7,84%​
52500250000
0,00%​
help said:
Thanks!
c)
month.
pqrr-q|r-q|
335003250-250250
7,69%​
3,234003570170170
4,76%​
3,532503100-150150
4,84%​
430002890-110110
3,81%​
4,527502550-200200
7,84%​
52500250000
0,00%​
You have calculated the percentages correctly.
How good the estimate is depends on what it is to be used for and what the alternatives are.
Plot q and r against p. Does it suggest a better formula for q?
  • · Replies 18 ·
