Undergrad Retaining Linear Terms of v and δ in Expansion Calculations
The discussion focuses on the retention of linear terms in the ratio of velocity (v) to density perturbation (δ) during expansion calculations. Key expressions include ##\frac{(v•\vec \nabla)v}{a(t)}## and ##\vec \nabla•[\rho(1+\delta)v]##, where the first term cancels out and the second is simplified to ##\frac{\rho(\nabla•v)}{a}##. Participants clarify that the focus is on linear terms in the ratio ##\frac{v}{\delta}##, emphasizing that higher-order terms can be neglected when ##|\epsilon| \ll 1
. PREREQUISITES
  • Understanding of vector calculus, specifically divergence and gradient operations.
  • Familiarity with perturbation theory in fluid dynamics.
  • Knowledge of cosmological expansion parameters, particularly scale factor a(t).
  • Basic grasp of linear approximations and their applications in physics.
  • Study the implications of linear perturbation theory in cosmology.
  • Learn about the mathematical treatment of divergence and gradient in fluid dynamics.
  • Explore the significance of small parameter expansions in physical models.
  • Investigate the role of density perturbations in the evolution of cosmic structures.
Researchers in theoretical physics, astrophysicists, and students studying cosmology or fluid dynamics who are interested in the mathematical foundations of expansion calculations and perturbation theory.
Apashanka
While doing some calculations I came across some terms which are ##\frac{(v•\vec \nabla)v}{a(t)}## and ##\vec \nabla•[\rho(1+\delta)v]## where all quantities have spatial dependence other than "a" which has only time dependence ,
the first term here is canceled and the the second term is rewritten as ##\frac{\rho(\nabla•v)}{a}## and the argument is given "retaining only linear terms of ##v /\delta##"
Can anyone please help me in how to check this out??
Presumably ##|\frac{\nu}{\delta}|## is small.
Sorry I didn't got ,it's linear terms of "##v##" or "##\delta##"
Why would "v/\delta" mean anything other than v divided by \delta? If you mean terms linear in two independent variablews, say "linear in v and \delta".
If |\epsilon| \ll 1 is small, then the most significant terms are those independent of \epsilon and those which are linear in \epsilon. Higher order terms can be neglected.
Linear in the ratio ##\frac{\nu}{\delta}##.
Apashanka said:
Sorry I didn't got ,it's linear terms of "v" or "δ"
I believe that linear in the ratio is the only reasonable meaning. I sincerely doubt that "/" should be interpreted as "or".
