Linear to logarithmic scale conversion
To convert linear values to a logarithmic scale while normalizing them between 0 and 1, the formula x'i = (log(xi) - log(xmin)) / (log(xmax) - log(xmin)) can be used. This approach allows for the creation of log-log plots effectively. An example provided shows that with xmin and xmax set to 1 and 100, respectively, an input of xi equal to 10 results in x'i equal to 0.5, confirming the midpoint on a log scale. The discussion also touches on the programming language used, C++, which supports logarithmic functions. Implementing this formula in the program is the next step for the user.
jocasa
Hi!
I'm making a computer program that represents some quantities in a graph in this way:
x'i=(xi-xmin)/(xmax-xmin)
so that the possible values of x range from 0 to 1. This is a linear scale. I want to do the same with the logarithmic values of xi. That is, I want to implement a log scale in my graphs, also in the range from 0 to 1.
Can anyone tell me how to do it?
Thanks!
Mathematics news on Phys.org
jocasa said:
Hi!
Thanks!
Welcome to the PF.
What language are you programming in? Does it have any math libraries that cover logarithms?
I'm using C++ and it has both log and log10 functions, that is, log in base e and log in base 10.
I'm not sure if I made myself clear in my first post. I want to be able to make log-log plots, transforming the resulting plot into the [0,1] interval.
jocasa said:
Hi!
Thanks!
I think this will work:
x'i = (log(xi)-log(xmin)) / (log(xmax)-log(xmin))​
As a test, we can see that if xmin,max are 1 and 100, then xi=10 gives x'i=0.5. As it should, since 10 is halfway between 1 and 100 on a log scale.
Thanks! It makes sense to me. Now the problem is to implement it in the program, but I won't bother you with such a thing. Thanks again from Spain!
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
13K
  • · Replies 17 ·
9K
17K
