Load Cell Choice for dynamic checkweigher system
Zeshan is facing challenges with a load cell system in a chicken slaughterhouse that needs to weigh chickens quickly as they pass over a platform at high speed. The current S-type load cell and digital indicator combination is too slow to provide accurate weight measurements within the 350ms time frame. Suggestions include exploring lighter weighing platforms to improve response times and searching for specific load cells designed for high-speed applications. The term "check weigher" is recommended for further research, although Zeshan has encountered difficulties finding suitable load cells. The discussion highlights the need for industry solutions to optimize weighing systems in fast-paced environments.
Muhammad Zeshan
Hello everyone, Greetings of the day.
My name is Zeshan, I am automation engineer, I am stuck in problem of automation of weighing and sort system in chicken slaughter house using plc and load cell. Everything is done right but load cell is not giving me the right weight to make the right decisions. I have a "moving line of hanging chickens" running at 8000 chicks/hr, the platform where the load cell is connected that has a length of 11.5cm and the time for one chicken to pass over that plat form is 350ms. now the problem is that the conventional s.type load cell and digital indicator combination which i am using is not fast enough to determine the exact weight of chicken in this short time. the min capacity of load cell should be 30kg(plat form assembly + 2kg chicken)
So please suggest me which type of load cell and indicator i should use to match the speed of the system.
This problem has been solved by industry. A good search term is "check weigher". Wikipedia has a good entry here:
https://en.wikipedia.org/wiki/Check_weigher
It gives various suggestions for methods.
I also think your weighing platform is much too heavy compared to what you are measuring and that combined mass is slowing the response of your measuring system.
Thanks for your response, I have searched with "check weigher" term but all platforms throw me with different company made checkweigher assemblies like CAS and others but I can't find a specific load cell which I can use in my system..
Dear Muhammad
did you solve your problem ?
can you tell us how ?
Yorgos
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
