Load current from two voltage sources with reactances
183 replies · 77K views
Ok.
I haven't checked your maths, but using that, you will now have a Voltage, Vth connected to j2.4, connected to Z_load, with current, i through the load.
Calculate Z_load (pretty simple)
Hence current in load is:
Vth = ...
The current in the load will be
Vth/(Zth+ZL) which from this I'm going to go for.
664 + j249/ j2.4 + 40.95 + j28.68
Therefore
IL= 7.36 - j3.95
In polar 8.35angle28.2
Therefore
IL= root2 x 8.35 sin (100 pi t + 28.2)
Is that the right way?
Ok, I'm going to start again and work my way through making sure I get each stage right. Then I'll post my calculations and results.
Thank you magician, you've been a massive help! :)
Just a quick one, the -v1+ j4 x I + j6 x I + v2 that's from nodal analysis isant it?
Ok, what I have from the stage where the voltages are converted to polar/rectangular
V1= j415
V2= 415
Using
-v1 + (j4 x i) + (j6 x i) + v2
i = 41.5 + j41.5
Therefore:
Vth = j6 x i + v2
Now I have:
Vth = 166 + j249
Zth = j2.4
ZL = 35 + j 35.7
Current flowing through load is
iL = Vth / (Zth + ZL)
iL = 5.71 + j0.89 or 5.77angle8.86 or root2 x 5.77 sin (100 pi t + 8.86)
I thought I had it right, but then did the superposition theorem in the next question and the answers are completely different.
Okay, so your Thevenin approach looks good, and your answer looks fine.
For the superposition version, can you first describe in broad strokes what your approach is?
Hi Guys,
I've pretty much got my head around everything up to finding the current for the Thevenin model... -v1 + (j4 x i) + (j6 x i) + v2 = 0 ... -415 + (j4 * I) + (j6 * I) + 415 = 0
but I'm really struggling with how to approach the complex math to achieve i = 41.5 + j41.5
I'm not looking for a complete breakdown but please could someone show me how to approach this?
Thank you
Hello,
I too am having a terrible time with this question, I've had a look through this post but the only thing i can gather is that the folders I've been sent really are glorified paper weights!
If someone could talk me though and teach me the theory behind this that would be amazing, as i really am at a loss and am too stubborn to move on until this question is completed.
Thank you!
I've found the equivalent Rt as j2.4 but I'm afraid I'm unsure as what to do next?
Okay so I've got up to..
V1 = j415
V2 = 415
But when substituted into the circuit equation for 'i' ( -V1+(j4*i)+(j6*i)+V2 = 0) I'm getting i = -41.5 + j41.5, where am i going wrong?
I've completed parts a) and b) thanks to some heavy swatting and a whole load of coffee.
now to part c) anyone willing to lend me a hand with this one?
V1 = j415
V2 = 415
I too am getting I = -41.5 + j41.5.
-V1 + (j4 * I) + (j6 * I) + V2 = 0
-j415 + (j4 * I) + (j6 * I) + 415 = 0
j10 * I = -415 + j415
I = (-415 + j415) / j10
I = -41.5 + j41.5
Why am i going wrong there?
I = -41.5 + j41.5
I = (-415 + j415) / j10 can be rewritten as:
I = -415 / j10 + j415/j10 and further as:
I = 1/j * -415/10 + j/j * 415/10
If 1/j = -j and j/j = 1, what do you get if you carry out the arithmetic?
It really helps to have a calculator that can do complex arithmetic.
magician said:
Thevenin equivalent voltage is
Vth = 6j * i + v2
Vth = 299.26∠56.31
What formula have you used to calculate this?
Are you asking how to go from this rectangular form: Vth = 6j * i + v2
to this polar form: Vth = 299.26∠56.31 ?
Or are you asking about the substituted values for i and v2?
No i can convert rectangular to polar, I'm looking to find out how you go about getting Vth when you've multiple sources of voltage.
magician said:
FIGURE 1 shows a 50 Ω load being fed from two voltage sources via
their associated reactances. Determine the current i flowing in the load by:
(a) applying Thévenin’stheorem
(b) applying the superposition theorem
(c) by transforming the two voltage sources and their associated
reactances into current sources (and thus form a pair of Norton
generators)
[/B]
Would i be correct in saying that i = 5.71 + j0.892 A?
That's from Vth / (Rth + Rl) = 166 + j249 / (0 + j2.4 + 35 + j35.71).
That's correct; now all you have left is part (b) and (c). :smile:
Here is a link for anyone still struggling, it will cover the grey areas. I found it helpful, I hope you will too. Check out the 2nd/last example he gives -http://youtu.be/25axDabtoFk
How did you guys get on with part c? I've got so far as a refined circuit with a current source in parallel with Rn (j2.4) and the 35+j35.707 Load, but can't seem to get past this as my numbers don't add up! I'm not getting the same as i did in a or b?
What is the value of the current source? How did you determine it? It''s easier to see where you've gone wrong when you show your work.
Hi, apologies for the lack of detail in the first post.
So i have 103.75-j69.16 for the current source, as stated above, and also have the circuit written out as the current source with Rn on one parallel branch, and the Load on the other.
To convert the current to voltage i used (103.73-j69.16)*(j2.4) = 165.98 + j248.95, so this becomes the voltage and the circuit is then rewritten in series. Using ohms law, the load resistance and this voltage, the current value comes out at 5.87 + j1.11, which is close, but not exactly what I'm looking for?
Sorry, not 'as above', that applies to another thread!
gneill said:
With the angle and the magnitude you have the load impedance in polar form. Thus
$$Z_L = 50 \Omega ~~\angle 45.57°$$
You can convert this to rectangular form if you need it that way.
By the way, before you dive into the calculations for the Thevenin equivalent, take a close look at the definitions of the voltage supplies. While they both have the same frequencies they won't have the same phase angle (why is that do you think?).
You need to include the j2.4 ohms in series with the load impedance, all driven by the voltage of 166 + j249 volts.
Thankyou, I've realized my mistake, I've had the correct method all along, just one of my values was out by 0.1. Typical.
Thanks again.
their associated reactances. Determine the current i flowing in the load by:[/B]
generators)
Straight question: would it be seen as incorrect here if i just converted the thevenin's equivalent voltage that i calculated in thevenin's equivalent circuit in part a) using the IN = VTH/RTH formula?
