Load Displacement to stress strain
The discussion focuses on creating a stress-strain curve from tensile data involving displacement and load for PVC material. The user successfully calculated the cross-sectional area and derived stress using the formula: stress = (load * 9.8) / cross-sectional area. They reported a maximum stress of approximately 65,000,000 pascals at 40% strain, which raised concerns about the accuracy of their results compared to known values for PVC. Participants suggested verifying the calculations against material specifications from sources like MatWeb.
  • Understanding of tensile testing and stress-strain relationships
  • Familiarity with unit conversions (kgf to pascals)
  • Knowledge of material properties, specifically for PVC
  • Ability to use online material databases like MatWeb
  • Review the calculation of stress and strain in tensile testing
  • Explore the properties of PVC using MatWeb for accurate comparisons
  • Learn about the significance of cross-sectional area in stress calculations
  • Investigate common errors in stress-strain curve generation
Students in materials science, engineers conducting tensile tests, and professionals analyzing the mechanical properties of polymers like PVC.
8-)
Hello, so here is my problem.
I am given tensile data, which is displacement (mm) and load (kgf). also I am given width(mm), thickness(mm), gauge length (mm) and cross-head speed (mm/min). How do i make a stress strain curve from this?
So far i have multiplied width by thickness to find cross sectional area (in metres squared). Then i divide load (kgf) *9.8/cross sectional area (m^2) to find stress. and displacement (metres) over gauge length (metres) to find strain. I am getting around 65,000,000 pascals for maximum stress at around 40% strain. its for PVC. does that make sense?
thanks!
not compared with steel whose weakest strength would be around 250,000 pascals. (Check this yourself from some independent source)
Yeah it seemed off, where am i messing up?
If you search www.matweb.com for PVC, and read the material specs carefully, you may find data to compare with your results.
16K
