Loading .nii images while saving memory
  • Topic: Python
  • Thread starter Thread starter BRN
    Images Memory
BRN
Hello everybody,
for my Deep Learning exam, I have to develop a project that provides for the generation of 3D images in format .nii using the DCGAN algorithm trained with some real images of MRI scans of brains of patients with Alzahimer.
I have a serious problem. I should load three different datasets that weigh 3GB, 5GB and 8GB respectively. Unfortunately I am forced to use an old PC with only 4GB of RAM and 2GB of Swap memory, so I am impossible to upload the files at one time using this simple code:
[CODE lang="python" title="loading files"]
train_data = []
data_path = './data/ADNI_test/'
for i in range(len(filenames)):
mri_file = data_path + filenames
train_data.append(nib.load(mri_file).get_fdata())
[/CODE]
Would any of you know how to give me some alternative solution? Is there a way to upload the files a little at a time without overloading memory? In DCGAN algorithm the batch size is set to 64 files, but I will certainly have to decrease to 30.
Thank you!
I wouldn't have thought it would be necessary to have all the image files in memory; can you provide the ML engine with an iterator that loads each file on demand?
I hope it can be done, but at the moment I don't know how.
Should the iterator be implemented directly in the loss function of the GAN discriminator?
[CODE lang="python" title="discriminator"]
def discriminator_model(strides, kernel_size, input_img, weight_initializer, downsample_layers):
rate = 0.2
filters = input_img.shape[1]
model = Sequential()
model.add(tf.keras.layers.Conv3D(strides, kernel_size, filters, input_img.shape, padding = 'same',
kernel_initializer = weight_initializer))
model.add(tf.keras.layers.LeakyReLU())
model.add(tf.keras.layers.Dropout(rate = rate))
for l in range(downsample_layers - 1):
filters = int(filters * 2)
model.add(tf.keras.layers.Conv3D(strides, kernel_size, filters, padding = 'same'))
model.add(tf.keras.layers.Flatten())
model.add(tf.keras.layers.Dense(1))
return model
def discriminator_loss(real_output, fake_output):
real_loss = cross_entropy(tf.ones_like(real_output), real_output)
fake_loss = cross_entropy(tf.zeros_like(fake_output), fake_output)
total_loss = real_loss + fake_loss
return total_loss
[/CODE]
where 'real_output' would be the real image that is compared with that artificially generated.
Some idea?
