iste
- 297
- 128
- TL;DR
- Recent theory of spin implies localized elliptical polarization in fields. In field media with an underlying microscopic particle theory available, this is mediated by the elliptical orbit of classical particles. It then seems logically possible - and easily visualizable - for those particles to evince nonlocal correlations (albeit not all aspects of photon polarization correlations) given that they share the same fundamental description. Importantly, this mechanism is entirely local.
Spin (and therefore photon circular polarization) can be constructed generically in terms of intrinsic rotations on vector fields, whether describing classical and quantum physical systems: e.g.
https://scholar.google.co.uk/scholar?cluster=14889979702374754652&hl=en&as_sdt=0,5
Building on this kind of construction, a relatively recent model ascribes the cause of spin to elliptical polarization localized to individual points within those fields. This elliptical polarization is proportional to the local spin density that is integrated over the field to get the total spin: e.g.
https://scholar.google.co.uk/scholar?cluster=15022687356306265602&hl=en&as_sdt=0,5&as_vis=1
(sections 5 & 6)
The kinds of rotational motion implied by this localized polarization are experimentally observable. It also resolves a paradox regarding the spin of plane waves, and explains the enigmatic "virtual" properties of spin that distinguish it from orbital angular momentum (i.e. how there is spin current without probability density transport). Due to how the construction of spin is so generic, this localized polarization has been formulated for a number of systems such as electromagnetic waves, water, acoustic waves, electron plasma and the electron quantum state (spinning probability current). It then implies localized elliptical orbits of particles whenever such a microscopic theory is available; for water, the predicted trajectories have been observed via probe particles (depiction in paper below).
https://scholar.google.co.uk/scholar?cluster=5115823896615614796&hl=en&as_sdt=0,5&as_vis=1
https://scholar.google.co.uk/scholar?cluster=2602243500647624252&hl=en&as_sdt=0,5&as_vis=1
https://scholar.google.co.uk/scholar?cluster=17892291218685033829&hl=en&as_sdt=0,5&as_vis=1
Importantly, the local elliptical polarization possesses the same properties as any classical or quantum descriptions of photon / light polarization, regardless of what medium is being described. For instance, local circular polarization at a point in space can be described in terms of two interfering orthogonal components that are ±90° phase-shifted, instantiable by circular orbits of particles. If we then additionally have a ±90° phase shift between the rotations of two separate particles, they would clearly display similar kinds of anti-correlations as entangled photons in virtue of the periodicity of their respective orbits. When one particle is experiencing the vertical part of its motion, it would imply that the other particle is in the midst of a horizontal part and vice versa (or when comparing any other two perpendicular pairs of directions). You could fix the phase relation at some initial source and then this correlation could be maintained without communication so long as the two particles keep orbiting in the same way undisturbed, even if they travel very far apart. Because of the continual orbiting, any measurement of particle direction would obviously not be pre-defined at source despite the anti-correlations. This then suggests that it is at least logically possible for nonlocal correlations of classical particles to be mediated by a mechanism that is entirely local. The particles don't even need to have locally interacted so long as the appropriate phase relation can be set.
In a paper by Jung:
https://www.frontiersin.org/journals/physics/articles/10.3389/fphy.2020.00170/full
They derive polarization correlations entirely in classical optics from a phase shift for circularly polarized light + Malus Law. From this, it seems that, though the orbital motions of particles obviously could not explain superposition or probabilistic aspects of measurement which would be connected to the local Malus Law aspect, this mechanism does seem to be able to account for the entire non-local aspect of these correlations.
(sections 5 & 6)
In a paper by Jung:
