Check My Logs & Exponential Homework Answers
  • Thread starter zebra1707
  • Tags
    Exponential
In summary, The student attempted to solve an equation that was written in a confusing way, and was not able to correctly answer the question. They eventually found the answer using a calculator.
zebra1707
107
Greetings - can someone please check my work, many thanks
If x = 12.4 Find the value of ... correct to two sig fgures
8^(4x/3) / log(base 10) (5x-3/x^0)
= 8^(16 8/15) / log(base 10) (5(12.4)-3 / 1)
= 4.8 x 10^14 (via calc 4.818429574)
Many thanks
This expression, (5x-3/x^0), is ambiguous. Is it (5x - 3)/1 or 5x - (3/1)? If it's the former, you're missing some needed parentheses.
Neither of these expressions is right. Starting with 8^(4x/3), how did you get 8^(16 8/15)? I'm assuming the part in parentheses is 16 + 8/15. If you substitute 12.4 for x, and multiply by 4/3, what do you get?
How did you get 4.8 x 10^14? That would be 480,000,000,000,000, nowhere close to 4.818...
zebra1707 said:
Many thanks
Hi Mark
For this question - I need to substitute 12.4 into all x values.
(5x-3/x to the power 0) so if you substitute 12.4 into the x in this part of the equation (12.4^0), yes, you will get (5(12.4)/1).
Is a substitution question.
I don't yet understand how to add the Maths chararcters in the Forum.
Cheers
zebra1707 said:
Hi Mark
That much is obvious.
No you don't. Where did the 3 go?
I still don't know what you mean when you wrote (5x-3/x^0), so please read what I wrote in my previous post more carefully and answer the questions that I asked.
Cheers
Really sorry,
8^(4x/3) (divided by sign) log(base 10 subscript) (5x-3/x^0) - this is exactly how the question is written.
x to the 0 power is 1 so log(base10)(5x-3/1) = log 59
8 to the power of 4x/3 if you substitute 12.4 into x you get 8 to the power of 16 8/15
So. 8 to the power of 16 8/15 or (16.533333.) (divided by ) log(base10)(5x-3/1) = log 59.
Hope that helps - otherwise not sure how I can explain this further.
If I do this again I get 1.6 x 10^14
Cheers
Yes, it reduces to
[tex]\frac{8^{16.53333..}}{59}[/tex]
but I do NOT get "1.6 x 10^14" for that.
Thanks HOI, I am getting two different answers and getting confused.
Ill have another look at this. Cheers
This is a relatively straightforward problem in using a calculator. You shouldn't be getting two answers.
Thanks Mark, for all your help.
Cheers
1. What is the purpose of checking my logs and exponential homework answers?
Checking your logs and exponential homework answers allows you to review and confirm your work, identify any mistakes or errors, and improve your understanding of the material.
2. How often should I check my logs and exponential homework answers?
It is recommended to check your logs and exponential homework answers after completing each assignment, as well as before exams or quizzes to ensure accuracy and understanding.
3. What should I do if I find a mistake in my logs and exponential homework answers?
If you find a mistake, take the time to correct it and understand where you went wrong. This will help you avoid similar mistakes in the future and improve your overall understanding of the material.
4. Are there any resources or tools that can help me check my logs and exponential homework answers?
Yes, there are various online resources and tools that can assist with checking your logs and exponential homework answers, such as online calculators or step-by-step solutions guides.
5. Should I only check my logs and exponential homework answers for correctness?
No, it is also important to check for understanding. Make sure you can explain the concepts and steps to solving each problem, rather than just copying the correct answers.
  • Precalculus Mathematics Homework Help
