Long Division and Remainder Theorem
FritoTaco
NO TEMPLATE BECAUSE MOVED FROM ANOTHER FORUM
Hello,
I've been trying to figure out how it works for complicated problems, I know how to use long division, but I'm not understanding how this process is done for a problem like I have.
Instructions: Write the function in the form ƒ(x) = (x - k)q(x) + r for the given value of k, and demonstrate that ƒ(k) = r
Problem: ƒ(x) = -4x³ + 6x² + 4,
k = 1 - √3 <--- when plugging in q in divisor, signs change as you can see in my picture.​
My Work:
So as you can see from my first attached file, I knew that if I wanted to cancel out 4x³ in the dividend, I would multiply 4x³ on top (quotient) with -1 (divisor). But I also now have to multiply 4x³ with √3. I don't know how to answer it? That's where my question mark is.
In my second attachment, you can see I put what I think is right. Then I drop down the 6x² because that's what you do in long division. So the 4x³ cancels out, but then I have two different degrees in the next part. I don't think I can do anything with that.
Another thing is that you've probably read the "Remainder Theorem in the question, I've already done that here so that's fine. I get a remainder of 0. This is the remainder I should get when I long divide.
Remainder Theorem
ƒ(1 - √3) = -4(1 - √3)³ + 6(1 - √3)² + 12(1 - √3) + 4
Solve: equals 0, so remainder is 0.
Then, for the answer, it's asking to put into form of, ƒ(x) = (x - k)q(x) + r. I already have (x - k) which is the (-1 + √3), I would multiply that with q(x), which is what I'm stuck on for getting the quotient in long division. Lastly, I would add the remainder (r) which there is none.
  • Handwritten polynomial long division: divisor -1 + √3 under dividend -4x³ + 6x² + 12x + 4, with first quotient term 4x³ and partial subtraction -4x³ + ?; to the right, k = 1 - √3.
  • Handwritten long division on a whiteboard: divisor -1 + √3 into -4x³ + 6x² + 12x + 4, with quotient term 4x³ on top and a note in the margin saying the 6x² and 4x³ terms have different degrees so they cannot be added.
Hello,
My Work:
Remainder Theorem
A screen shot of your 2nd division attempt:
Handwritten polynomial long division with 4x^3 as the quotient term over divisor -1 + √3, dividend -4x^3 + 6x^2 + 12x + 4, and a subtraction line -(-4x^3 + (4x + √3)^3 + 6x^2) with some terms crossed out.
You need to divide by x - k, which in this case is ##\ x-1+\sqrt{3\,}\ .\ ## You left out the ##\ x\ .##
I think I know what you're saying but here is what I have so far.
  • Handwritten polynomial long division on a whiteboard dividing -4x^3 + 6x^2 + 12x + 4 by x - 1 + sqrt(3), with the quotient terms and subtraction steps shown and a side note k = 1 - sqrt(3).
https://www.physicsforums.com/attachments/105992
Handwritten polynomial long division on a whiteboard: divisor x - 1 + √3 with a quotient term -4x^3 being written, subtraction line showing -(-4x^3 + (4x - 4√3)x^2), and a partial remainder line (2x^2 + ?).
You have unbalanced parentheses and an x2 in the wrong place, or an extra x2.
Handwritten expression: minus, open parenthesis, negative 4x cubed plus open parenthesis 4x squared minus 4 times the square root of 3, close parenthesis, x squared, with a line drawn under it.
I suggest you leave the coefficient of x2 intact, that is to say, write the above line as:
##\ -(-4x^3+(4-4\sqrt{3\,})x^2)\ ##
With long division, keeping track of all those signs gets to be a pain. Do you know synthetic division ?
Haha, it's funny how you mention synthetic division just now. I asked my professor today where I left off with you and he said to use synthetic division. Hey, thank you very much for your help, I do appreciate it, it helped me understand more.
  • Handwritten synthetic division with root 1 minus square root of 3, coefficients -4, 6, 12, 4, producing bottom row -4, 2+4√3, 2+2√3 and remainder 0, with expansions and factored form f(x) = (x - 1 + √3)(-4x² + (2+4√3)x + 2√3) + 0.
You are welcome, and thanks for posting your final result. I'll display the final image below:
Handwritten synthetic division with root 1 - √3 and coefficients -4, 6, 12, 4, yielding quotient -4, 2+4√3, 2+2√3 and remainder 0; below, the factored form f(x) = (x - 1 + √3)(-4x² + (2+4√3)x + 2√3) + 0.
