Longtime lurker here, composite function problem
12 replies · 2K views
Poset
Let f(g(h(x))) = 1/(2-x)
Find g(x) if:
f(x) = (x^2) - 1
h(x) = 3x+12. The attempt at a solution
This is what I have:
g(h(x))^2 -1 = 1/(2-x)
g(h(x) = sqrt((3-x)/(2-x))
I'm not sure how to get the h(x) out of this to leave me with just g(x). Please point me in the right direction.
Thank you!
Thank you for your reply. Am I right to assume that the calculations to g(h(x)) I did are correct? And what you are implying is that to get g(x) I need to go backwards from h(x) using the inverse of g(h(x)) and y = h(x) = 3x+1? I'm sorry it's not that obvious to me.
Your second line isn't far off. Then if you replace x there with y=h-1 you'll get g(y).
Find g(x) if:
f(x) = (x^2) - 1
Thank you!
You've got:
##g(h(x)) = \sqrt{\frac{3-x}{2-x}}##
Why not take one more step?
##g(3x+1) = \sqrt{\frac{3-x}{2-x}}##
Can you see what to do to finish things off?
On your last step I see you substituted x with y=3x+1 on the left-hand side, but not the right-hand side. In other words it should be 3-y (etc). Then you should have g(y) but you can set y=x to get g(x). To check your answer calculate f(g(h(x))) & see what you get.
Nice I just got this. Thank you all for your help
g(x) = sqrt((10-x)/(7-x))
I spent this entire time trying to figure this out. I really couldn't find any similar examples on the internet.
Find g(x) if:
f(x) = (x^2) - 1
Thank you!
Do it systematically: ##f(g(h(x)) = g(h(x))^2 - 1## and ##g(h(x)) = g(3x+1)##, so ##f(g(h(x)) = g(3x-1)^2 - 1##.
PeroK said:
You've got:
I like PeroK's reply here.
Two things to point out to Poset:
First of all; f(x) is not a 1 to 1 function.
So, when you find ##g(h(x)) = \sqrt{\frac{3-x}{2-x}}## , you should include a ± , so you can choose either sign in finding g(x). Thus the choice for g(x) is not unique.
##\displaystyle g(h(x)) = \pm\sqrt{\frac{3-x}{2-x}}##​
Second: The composite function, ##\ f\circ g\circ h\ ##, may have a more restricted domain than the implicit domain of ##\ \displaystyle k(x)=\frac{1}{2-x}\ ##.
Added in Edit: I've been working on this while the recent posts have come in.
Note: ##\displaystyle\ \frac{10-x}{7-x}=\frac{x-10}{x-7}##
I thought this might be of interest.
Below is a graph of the composite function y = f(g(h(x))), (in black). The range is restricted to y ≥ -1, because the final function, f, has a range, [-1,∞) .
The missing piece of the graph for y =1/(2-x) is shown dotted in grey.
Just as a matter of interest: what package did you use to make the graph?
