Looking for counterexample in inequality proof
The discussion centers on the validity of working backwards in inequality proofs, specifically using the example of proving that \(a^2 + b^2 \geq 2ab\). Participants highlight that while starting from the conclusion and attempting to derive the inequality can appear convincing, it often lacks rigor. A critical point made is that each step in the proof must be reversible; otherwise, the proof may fail. Examples provided include the misuse of inequalities and the importance of using equivalence arrows in logical reasoning.
  • Understanding of basic algebraic inequalities, specifically the Cauchy-Schwarz inequality.
  • Familiarity with the concept of reversibility in mathematical proofs.
  • Knowledge of the properties of squares and non-negative numbers.
  • Experience with logical implications and equivalences in mathematical reasoning.
  • Study the Cauchy-Schwarz inequality in detail and its applications in proofs.
  • Learn about reversible transformations in mathematical proofs.
  • Research common pitfalls in mathematical reasoning, particularly in inequality proofs.
  • Explore examples of non-reversible steps in proofs to understand their implications.
Mathematics educators, students learning proof techniques, and anyone interested in the logical foundations of inequalities will benefit from this discussion.
cerealkiller
Hi guys,
I have to teach inequality proofs and am looking for an opinion on something.
Lets say I have to prove that a2+b2≥2ab. (a very simple example, but I just want to demonstrate the logic behind the proof that I am questioning)
Now the correct response would be to start with the inequality (a - b)2≥0, then progress to:
a2+b2-2ab≥0
∴ a2+b2≥2ab.
What many students do, as it is generally much easier, is to start with the required result and work backwards:
i.e.
a2+b2≥2ab
a2+b2-2ab≥0
∴ (a - b)2≥0, which is true, ∴ the initial result must also be true.
Can anyone provide an example where starting with the result and working toward a true statement will not work? My colleagues would generally discourage this approach but it would be much more convincing to students if I could show them a situation where it won't work.
Thanks for the help guys!
Mathematics news on Phys.org
Here's my favorite:
1 = 2~\Rightarrow~1\cdot 0 = 2\cdot 0~\Rightarrow~0 = 0
Thanks! Are there any others that you know of? There are some obvious no-nos, multiplying both sides by 0 being one of them, but I was hoping for one that was maybe a little more subtle.
cerealkiller said:
a2+b2≥2ab
a2+b2-2ab≥0
That example is OK because each step is reversible. To illustrate a broken usage you need to introduce an irreversible step.
a2+b2≥2ab+c2
a2+b2-2ab≥c2
(a - b)2≥c2≥0
Or just
a≥b
a2≥b2≥0
Hence a2≥0, which is true...
When working "backwards" it's as haruspex says important that every step is reversible. So instead of implications arrows, you are looking for equivalence arrows, or simply backwards implication arrows. If you're not using only equivalence arrows, you might want to do at least the steps without equivalence arrows of the proof in the right direction.
I would however not discourage this way of proving inequalities, it's extremely helpful to start out with what you want to prove and try to reversibly find an inequality you can easily prove, and not very instructive to look for some random inequality of which your original one should follow from.
Well, it's kind of easy to produce an example where you have a correct inequality and work your way to a correct one, but not providing a proof of the original inequality. Suppose you want to prove that (a^2+b^2)(c^2+d^2) \geq (ac+bd)^2 (Cauchy-schwarz in two variables) then you could try to argue as follows:
(a^2+b^2)(c^2+d^2) \geq (ac+bd)^2 \Rightarrow (a^2+b^2)(c^2+d^2) + (ac+bd)^2 \geq (ac+bd)^2 \Rightarrow (a^2+b^2)(c^2+d^2) \geq 0 which is true, but this is obviously not a proof.
a2+b2-2ab≥0
∴ a2+b2≥2ab.
That is "a" correct response provided the theory (a-b)^2 \ge 0 has already been covered in the course. Since proofs employ assumptions and theorems previously established, where a proof can begin depends on the organization of the course materials.
i.e.
a2+b2≥2ab
a2+b2-2ab≥0
Doing mathematics is compromise between what is logically correct and what humans can do efficiently. Working backwards is a valuable technique. Students who work backwards usually don't write words that create a correct proof. Many instructors allow it anyway.. (Such papers are easier to grade than a formal proof! Concerns about human efficiency include concerns about efficient marking of papers.) Many instructors let students "prove" trig identities and write epsilon-delta "proofs" by working backwards.
In view of what other posters explained about the need for reversibility, try (a^2 + b^2 - 2ab ) \ge -1
