Looking For Help Understanding Bell's Theorem, Hidden Variables & QM
80 replies · 10K views
Lynch101
TL;DR
A few questions on Bell's inequality, which might serve as a means for helping me better understand Bell's Theorem, Hidden Variables & QM.
I was revisiting @DrChinese 's Bell's Theorem with Easy Math which sparked a few questions, which I am hoping might offer a potential path to a deeper understanding of Bell's Theorem and Quantum Mechanics (QM) in general.
The explanation uses light polarisation experiments to explain how we arrive at Bell's inequality.
We can't explain why a photon's polarization takes on the values it does at angle settings A, B and C. But we can measure it after the fact with a polarizer at one setting, and in some cases we can predict it for one setting in advance. The colors match up with the columns in Table 1 below. (By convention, the 0 degrees alignment corresponds to straight up.)
ASSUME that a photon has 3 simultaneously real Hidden Variables A, B and C at the angles 0 degrees, 120 degrees and 240 degrees per the diagram above. These 3 Hidden Variables, if they exist, would correspond to simultaneous elements of reality associated with the photon's measurable polarization attributes at measurement settings A, B and C.
[W]e are simply saying that the answers to the 3 questions "What is the polarization of a photon at: 0, 120 and 240 degrees?" exist independently of actually seeing them. If a photon has definite simultaneous values for these 3 polarization settings, then they must correspond to the 8 cases ([1]...[8]) presented in Table 1 below. So our first assumption is that reality is independent of observation, and we will check and see if that assumption holds up.
There are only three angle pairs to consider in the above: A and B (we'll call this [AB]); B and C (we'll call this [BC]); and lastly A and C (we'll call this [AC]). If A and B yielded the same values (either both + or both -), then [AB]=matched and we will call this a "1". If A and B yielded different values (one a + and the other a -), then [AB]=unmatched and we will call this a "0". Ditto for [BC] and [AC]. If you consider all of the permutations of what A, B and C can be, you come up with the following table:
(Emphasis mine)
It is pretty obvious from the table above that no matter which of the 8 scenarios which actually occur (and we have no control over this), the average likelihood of seeing a match for any pair must be at least .333
We don't know whether [Cases [1] and [8]] happen very often, but you can see that for any case the likelihood of a match is either 1/3 or 3/3). Thus you never get a rate less than 1/3 as long as you sample [AB], [BC] and [AC] evenly.
The fact that the matches should occur greater than or equal to 1/3 of the time is called Bell's Inequality.
Bell also noticed that QM predicts that the actual value will be .250, which is LESS than the "Hidden Variables" predicted value of at least .333
If [the experimental tests] are NOT in accordance with the .333 prediction, then our initial assumption above - that A, B and C exist simultaneously - must be WRONG.
Experiments support the predictions of QM.
When it says above to "assume that a photon has 3 simultaneously real Hidden Variables (HV) A, B and C [at the angles]" does this only apply to Hidden variables theories with these specific characteristics? Is it possible to have a HV theory which doesn't have these 3 simultaneously real Hidden Variables.
There is probably some basic answer to this, but in trying to think more about Bell's theorem, I was wondering if it would be possible that the photons are simply polarised North and South, where the line of polarisation (the axis?) would be the hidden variable and can take any orientation within 360 degrees? I was thinking that this would mean that any photon would have a probability 0.5 of passing a polarisation filter. For any pair of particles, there would be a probability of ≥0.25 of both photons passing through their respective filters.
F = fails to pass filter
P = passes filter
P/F = photon 1 passes/photon 2 fails
Pass = both pass their respective filters.There is probably lots wrong in that, but that is where my thinking has taken me, so any help to point out where I've gone wrong or gaps in my understanding would be greatly appreciated.
Reply
(Emphasis mine)
1. When it says above to "assume that a photon has 3 simultaneously real Hidden Variables (HV) A, B and C [at the angles]" does this only apply to Hidden variables theories with these specific characteristics? Is it possible to have a HV theory which doesn't have these 3 simultaneously real Hidden Variables.
2. There is probably some basic answer to this, but in trying to think more about Bell's theorem, I was wondering if it would be possible that the photons are simply polarised North and South, where the line of polarisation (the axis?) would be the hidden variable and can take any orientation within 360 degrees? I was thinking that this would mean that any photon would have a probability 0.5 of passing a polarisation filter. For any pair of particles, there would be a probability of ≥0.25 of both photons passing through their respective filters.
P = passes filter
1. This point has been debated by many, but the essential answer is: No, it is not possible that there can be a Hidden Variable theory that does not have "simultaneously real" values (answers to polarization measurements) for 3 or more (and possibly infinite) angles.
You can see this is the case from several different perspectives. From the theoretical side: This is the critical assumption in the Bell argument. He actually calls the angle settings a, b and c. See Bell (1964) after his formula (14). This is in response to the earlier and important EPR (1935) paper, which made a similar assumption. Their conclusion, which rested on this assumption, was that QM was not complete. They believed their assumption so obvious, that any other view was unreasonable.
"Indeed, one would not arrive at our conclusion if one insisted that two or more physical quantities can be regarded as simultaneous elements of reality only when they can be simultaneously measured or predicted. On this point of' view, since either one or the other, but not both simultaneously, of the quantities P and Q can be predicted, they are not simultaneously real. This makes the reality of P and Q depend upon the process of measurement carried out on the first system, which does, not disturb the second system in any way. No reasonable definition of reality could be expected to permit this."
Could there be other definitions of HVs that lack this assumption*? It would be hard, considering this is precisely the definition of a realistic theory in the first place. Moreover, from the practical side: they already knew that QM would predict perfect correlations if both Alice and Bob both measured P (or both Q - whatever they choose either to be). If there are perfect correlations, then this implies that the result must actually be predetermined.2. Hopefully you can now see the biggest problem with your hypothesis. That being on your chart. in the columns marked A/A, B/B and CC: There will be no F/P or P/F outcomes at all. So the statistics will be a mixture of F/F (50%) and P/P (the other 50%).
Note that in actual Bell experiments, a Polarizing Beam Splitter (PBS) is normally used rather than a Polarizer. That way you actually detect all photons (in the ideal case).*They of course also assumed that Alice's outcome would be independent (separable) from Bob's outcome (which is the Locality assumption). There are HV theories which do not include the Locality assumption.
Reply
Ah yes, of course! My bad, the idea of HVs is that it's already "programmed" in advance whether they will pass the filters. I was more focused on trying to see if there was a way to get a HV model to match the predictions of QM, which made me overlook that particular point.
Thanks for the clarification.
Reply
Am I right in saying that we're also interested in the cases where the outcome is the same, not just where both pass?
This is a very basic question, and I would anticipate the answer, but I just want to ask for the sake of certainty.
In practice, does the statistical analysis of the statistical sample of experimental observations select for equal numbers of the possible detector combinations? That is, in terms of @DrChinese's explanation, does it select for an equal ratio of AB:BC:AC?
I don't know what you mean by "select for". The statistical analysis will tell you what proportion of the observations fall into each category.
Reply
You may be describing what is called the “fair sampling loophole” - if some configurations of the hidden variables are more likely to go undetected in some detector configurations than others it is possible to find violations of the inequalities. This possibility has always been met with some skepticism because no one could propose a convincing (as opposed to a possible but contrived sort of devil’s advocate) model in which that would happen, but still the possibility existed.
However, this loophole was decisively closed by an experiment done a few years back.
I’ll post the link in a while if no one beats me to it.
Reply
However, this loophole was decisively by an experiment done a few years back.
Here’s a good one without the fair sampling loophole :
https://arxiv.org/abs/1508.05949
Reply
Cheers, I'll check out that paper.
Are there tests of QT which don't randomly vary the detector settings? As in, which test a statistical sample of only two different detector settings e.g. AB (as per Dr.C's) explanation above?
It's probably a gap in my understanding with regard to principles of statistics, but I'm wondering if each pairing of filters is treated as a statistically independent trial?
Almost all of them, possibly every one that was done before the discovery of Bell's theorem led to interest in correlations between results at different detector settings. It's such basic stuff that it was a lab exercise required of all physics majors when I was in college - and the point of the experiment was not to test QT but to test the proposition "Nugatory is competent to set up and operate lab equipment"
Reply
  • Love
  • Haha
Each entangled pair is treated as a separate trial, statistically independent of the previous and successive one. This is an assumption, but it is both reasonable and born out by observation of the statistical distribution of the behavior of the particle source.
Nonetheless it is an assumption. If you pull on this string you will eventually arrive at the only "loophole" that cannot be eliminated: superdeterminism. Search this forum for previous discussions of the idea - it is both irrefutable and an intellectual dead end.
Reply
I'm wondering about the independence of the filter orientations, as opposed to the entangled pairings. I know both of those are assumed to be statistically independent of each other, but I'm wondering about the independence of the filter settings with respect to each other (if that makes sense) - like how individual trials of rolling 2 dice are all independent of each other.
To clarify what I'm wondering about - and it's probably just that I'm reading it incorrectly or am missing a basic principle: is the likelihood of a match for each individual pair of filter settings not ≥ 0.25, if we don't know how often cases [1] and [8] occur?
From Dr.Ch's explanation:
Cases [1] and [8] actually always yield matches (3/3 or 100% of the time). We don't know whether these particular cases happen very often, but you can see that for any case the likelihood of a match is either...
We've had this discussion in previous threads of yours. The lack of statistical independence here is basically superdeterminism. There's no point in rehashing superdeterminism again here; as @Nugatory has said, it's already been discussed plenty in previous PF threads and the discussions lead nowhere.
Reply
I'm thinking along different lines this time, in line with what I, probably mistakenly, understand statistical independence to imply.
I was thinking that statistical independence of the choice of filter settings* would imply treating them as independent probabilistic events.
*Independent of other trials (of filter setting choices) as well as independent of the preparation of the photon pairs.
Not really.
Which is what superdeterminism denies.
PeterDonis said:
Not really.Which is what superdeterminism denies.
In this case I'm not trying to deny it, rather affirming it - at least as far as my understanding extends.
Which still leaves the discussion going nowhere. So you affirm superdeterminism: then what?
No, what I'm asking here would deny Superdeterminism (afaik).
I'm asking, if each filter combination is treated as a statistically independent event* (denial of Superdeterminism) would the probability of matching outcomes not be ≥0.25?
*Independent from other choices of filter combination as well as from particle preparation (denial of SD).
Again, I'm probably missing some nuance.
No, because superdeterminism is not the only possible interpretation of QM. All we really know is that QM correctly predicts the probability of matching outcomes that we actually observe, and that those probabilities violate the Bell inequalities or their equivalents. We don't know why that is: superdeterminism is just one possible "why".
Reply
Note, btw, that we can do statistical tests on the filter combinations, to verify that they at least appear to be statistically independent. Superdeterminism has to claim that that appearance is in fact invalid: that there is a connection between them "behind the scenes", it's just set up in exactly the right way to mislead us into thinking the combinations are statistically independent, when they actually aren't.
Reply
Sorry, I initially didn't understand what Superdeterminism had to do with it. I thought what I was asking implied the opposite.
I was thinking that treating each filter pairing as a statistically independent event was upholding statistical independence, but it doesn't uphold statistical independence of the filters and particle pairings.
Apologies, when I try to develop a better understanding of ideas I usually go back and forth with them and try to look at them from different perspectives. I sometimes get stuck on certain questions which are often quite basic. This is probably another pretty basic question.
I'm wondering what the distinction is between what I was doing here (looking at filter settings as statistically independent from other settings):
And this:
I'm wondering why it isn't the same reasoning as I was using, just applied to pairs of photons?A related question: why do we not consider the entire possibility space? If we discount cases [1] & [8] because we don't know how often those cases occur, the probability of seeing matching pairs would be 6/24 or ≥0.25.
I'm probably making some basic mistake here. I was just thinking about an explanation which helped me understand the Monty Hall problem and I (tried) applying it here.
If you are explicitly denying superdeterminism, you need to explicitly say so. Just saying "statistical independence" isn't enough, since, as I noted, a superdeterminist would claim that such independence is only apparent (since we can test for it but we have no way of actually knowing for sure that our tests aren't being superdetermined).
This is correct, yes. To fully deny superdeterminism you have to explicitly deny all such "behind the scenes" connections.
Reply
You can't. The Monty Hall problem is solvable by local hidden variables (the hidden variables are just what is actually behind the doors)--but Bell's Theorem and its equivalents prove that local hidden variables cannot explain our actual observations in cases like the experiment you are looking at here. That is the point of the chart showing the 8 possible combinations of results and the average correlations for each: no matter how you combine all of those, you can't get an average of 0.25--but when we actually run the experiment, we do get an average of 0.25! So no local hidden variable model can explain the actual results, because any local hidden variable model would end up producing a chart like the one you are looking at, which cannot possibly explain the actual results.
Reply
Your denominator is incorrect. If you discount cases [1] & [8], you have remaining 6x3=18 cases. The fraction is then 6/18, which is back to .333 (and well different that the quantum expectation of .25).
I was thinking to discount them, but not totally disregard them as possibilities. As in , they could still possibly occur, we just don't know how often, which would give rise to the "greater than" part of the inequality.
I was thinking that by doing so, to borrow a sentence in your explanation, "thus you never get a rate less than" 0.25.
if that makes any sense?
Sorry, what I meant was that, what helped me understand the Monty Hall problem was seeing the entire possibility space laid out.
I was looking at the possibility space in Dr C's explanation and wondering why we don't consider the entire possibility space.
Dr.C, for want of a better word, ignored the cases where each photon had hidden variables which would ensure it passed all 3 filters or the opposite, ensured it would fail all 3. The reason was that we aren't sure how often those instances occur.
His conclusion was that "thus you never get a rate less than 0.333"
I was looking at the possibility space and applying that reasoning. If we discount them (but allow for them to occur) you never get a rate less than 0.25. Assuming they occur occasionally, the probability of seeing matches across the statistical sample would be ≥0.25.
I assume I'm misconstruing something there, I'm just not sure what it is.
