Loop gain and source impedance with negative impedance model
8 replies · 3K views · last reply
genxium
I recently got a problem that confuses for days, the picture for this problem is in the attachment field, is there someone can tell me that, if an oscillator is topology is described using the negative impedance model in the picture, should I have R>r to ensure that the loop gain is larger than 1?
The second question is, is the current direction a significant element to consider ? Because to construct a negative impedance port, usually a voltage source or current source will be used, the source is directional.
I actually get different result by assuming different current directions in the second attached picture, I think the direction really matters, but if so, it'll be confusing that how I should choose the direction !
I'm afraid there's no equation for this question.
No meaningful attempt made. The port impedance I got for picture 2 is [itex]R_{eq}=\frac{U}{i_U}=\frac{Z_1 \cdot (Z_2+Z_3)}{(Z_1+Z_2+Z_3)+g_m \cdot Z_1 \cdot Z_2}[/itex], and for inverse direction current, the impedance I got is [itex]R_{eq}=\frac{Z_1 \cdot (Z_2+Z_3)}{(Z_1+Z_2+Z_3)-g_m \cdot Z_1 \cdot Z_2}[/itex]
  • Circuit schematic of a rectangular loop with a resistor labelled r on the left side and a resistor labelled -R on the right side, with a curved arrow inside the loop labelled Current.
  • Circuit schematic with impedance Z1 in a vertical branch from the input node carrying current i1, a series branch of Z3 carrying i3 into a node feeding Z2 (current i2) in parallel with a current source g_m·U, input current iU, and voltage U across the input terminals.
Which current(s) in particular are you referring to when you say "inverse current direction"? Is it the controlled source?
Thanks for your reply ^_^
I'm sorry for the poor statement, when i said "INVERSE DIRECTION", I meant the direction of "current" in picture 1, and direction of "[itex]i_U[/itex]" in picture 2.
Hmm. If iU is reversed then would not this imply that U is reversed also, yielding the same U/iU for the impedance?
Dear gneil, I'm afraid not, when I calculated [itex]R_{eq}[/itex] in the inverse current direction, I flipped the whole picture vertically, I think this reverses both the voltage and current :)
I don't see how the orientation of the drawing on paper could possibly change the circuit's operation!
My reasoning:
Use the transformation shown in the attachments.
[itex]Z_a=\frac{Z_1 \cdot Z_3}{Z_1+Z_2+Z_3}[/itex]
[itex]Z_b=\frac{Z_2 \cdot Z_3}{Z_1+Z_2+Z_3}[/itex]
[itex]Z_c=\frac{Z_1 \cdot Z_2}{Z_1+Z_2+Z_3}[/itex]
[itex]U=i_U \cdot Z_a+(i_U-g_m \cdot U) \cdot Z_c[/itex], the port impedance [itex]R_{eq}[/itex] is
[itex]R_{eq}=\frac{Z_1 \cdot (Z_2+Z_3)}{(Z_1+Z_2+Z_3)+g_m \cdot Z_1 \cdot Z_2}[/itex]
  • Circuit schematic of a delta-to-star transformation: left, a delta network with Z1, Z2, Z3 between nodes N1, N2, N3; right, the equivalent star with Za, Zb, Zc meeting at a central node, with a red dashed arrow between them.
  • Circuit schematic of a T-network with nodes N1, N2 and N3: Za in series from N1, Zb in series to N2, Zc from the junction down to N3, a dependent current source gm·U from N2 to N3, with voltage U across N1 and N3 and branch current iU in red.
I'm sorry gneill, you're right ~ Thanks a lot for your help ! But I'm still curious, is there any port impedance that would change subject to measuring direction (like flipping +/-)?
Sure, if the network contained some non-linear component(s) such as diodes.
