Lorentz invariance of [itex] E_p \delta ({\bf p}- {\bf q}) [/itex]
The expression E_p δ({\bf p} - {\bf q}) is not Lorentz invariant unless it is combined with the delta function δ(p^2 - m^2). The discussion highlights the importance of using the 4-dimensional delta function δ4(p - p0), which is inherently Lorentz invariant. The transformation of variables within the delta function, specifically replacing E with p^2, is crucial for maintaining invariance. The combination of δ(p^2 - m^2) and δ3(k - k0) yields a Lorentz invariant domain, while δ3(k - k0) alone does not preserve invariance.
  • Understanding of Lorentz invariance in the context of quantum field theory (QFT)
  • Familiarity with delta functions, particularly 4-dimensional delta functions
  • Knowledge of energy-momentum 4-vectors and their properties
  • Basic principles of transformations in relativistic physics
  • Study the properties of 4-dimensional delta functions in quantum field theory
  • Learn about the implications of Lorentz invariance in physical theories
  • Explore the derivation and applications of the invariant mass condition, δ(p^2 - m^2)
  • Investigate the role of energy-momentum conservation in particle interactions
Physicists, particularly those specializing in quantum field theory, researchers in theoretical physics, and students studying relativistic mechanics will benefit from this discussion.
LayMuon
Can anybody help me with the proof that E_p \delta ({\bf p}- {\bf q}) is a Lorentz invariant object?
I did a boost along z axes and used the formula \delta (f(x)) = \frac{\delta(x-x_0)}{|f'(x_0)|} and the factor in front of the delta function indeed is invariant but within the function I have something like this:
E_p \delta (p_z -(v(E_q-E_p)+q_z))
but not E_p \delta (p_z- q_z)
Thanks.
Nobody? :(
What makes you think it's Lorentz invariant?
Because in QFT we specifically choose a normalization in such a way as to get scalar product invariant.
Ok, now I understand! To distinguish between 3-dimensional and 4-dimensional quantities, let me call the energy-momentum 4-vector p, with components (E, k) and invariant norm p2 = m2.
To begin with, the 4-dimensional delta function δ4(p - p0) is clearly Lorentz invariant. Write this as δ(E - E0) δ3(k - k0). And now change variables on the first factor. In place of the variable E, I want to use the variable p2. Well, one can show that δ(p2 - m2) = (1/2E0) δ(E - E0). [There's a second term with δ(E + E0) if you want to include the negative energies.]
This gives us δ4(p - p0) = 2E0 δ(p2 - m2) δ3(k - k0), which is Lorentz invariant.
Thank you, I got it. I made a mistake in calculation.
That's good. By the way, the expression as you originally gave it is not Lorentz invariant. Only if you include the other delta function, δ(p2 - m2). And the variable you choose to replace E makes all the difference too. If you use some other f(E), you'll get something else instead of 2E0 as the factor in front.
But \delta (p^2-m^2) is Lorentz invariant.
Consider the domain where these functions are nonzero. δ4(p - p0) is nonzero at just a single point - of course that's a Lorentz invariant domain. And δ(p2 - m2) is nonzero on a hyperboloid - that's Lorentz invariant too.
But δ3(k - k0) is nonzero on an entire line - and that's not Lorentz invariant! It singles out a rest frame. And putting E0 in front of it doesn't change the fact.
It's only when you multiply the two of them together, δ(p2 - m2) and δ3(k - k0) -- then the product is nonzero on the intersection of the line and the hyperboloid, namely a single point again -- that you get back to a Lorentz invariant domain.
  • · Replies 31 ·
17K
