Lorentz Invariance?
  • Context: Undergrad
  • Thread starter Thread starter Purge
The discussion revolves around the concept of Lorentz Invariance, questioning its empirical validation and the implications of potential violations. Participants explore theoretical aspects, the nature of reference frames, and the challenges of testing Lorentz Invariance under various conditions, including low-speed scenarios and the existence of a "zero-velocity" frame.
  • Some participants argue that Lorentz Invariance has never been proven, only assumed, and that all observations are made from accelerating frames, which may obscure potential violations.
  • Others assert that Lorentz invariance has been tested to high precision and that classical mechanics is recovered at low speeds, questioning the validity of claims that low-speed tests have never been conducted.
  • A participant suggests that tests have not been performed from a "zero-velocity" reference frame, raising concerns about the possibility of a preferred frame defined by Higgs or gravity effects.
  • There is a discussion about the difficulty of defining "zero velocity" and the implications of acceleration versus speed in the context of inertial frames.
  • Some participants challenge the notion that Lorentz Invariance requires testing from a "zero-velocity" frame, arguing that valid tests of relativity can be conducted without such constraints.
  • Concerns are raised about the potential for Lorentz symmetry to be approximate or emergent at the Planck scale, with references to existing literature on hypothetical models.
  • Several participants emphasize the misunderstanding of relativity principles, particularly the absence of an absolute zero velocity and the implications of such a concept for Lorentz violation.
Participants express multiple competing views regarding the validity of Lorentz Invariance, the necessity of a "zero-velocity" frame for testing, and the implications of acceleration in defining inertial frames. The discussion remains unresolved with no consensus reached.
Limitations include the dependence on definitions of reference frames, the challenges of testing at low speeds, and the unresolved nature of Lorentz symmetry at the Planck scale. The discussion reflects varying interpretations of empirical evidence and theoretical implications.
Purge
[Mentor Note: Two thread starts merged into one]
So what I've been thinking about is how Lorentz Invariance was never proven, it was only assumed to be true. And when I think about the Universe, nothing is actually truly in an inertial reference frame. Everything is accelerating at relativistic speeds, including Earth. Doesn't that mean that no matter how many observations we make, we will always be blind to Lorentz violations that only happen at low speeds?
And if Lorentz Invariance doesn't hold, then one of the three assumptions that CPT symmetry relies on is broken and CPT violation is possible.
  • Skeptical
First of all, physics doesn’t prove things. It is an empirical science where you can test the predictions of a theory within the measurement errors of your experiment.
Second, (local) Lorentz invariance has been tested to high precision.
Third, at low speeds you just recover Newtonian classical mechanics. It is unclear why you think this has not been tested.
Lorentz Invariance has never truly been tested from a "zero-velocity" reference frame, so we may be moving through a preferred Higgs- or gravity-defined vacuum without knowing it. Like I already said, everything, including Earth, is accelerating at relativistic speeds.
Also, we can't test for Lorentz symmetry at the Planck scale, which means that it's possible that Lorentz symmetry becomes approximate or emergent.
Edit: To your third point, what I'm trying to say is that you cannot make that claim. NOTHING has ever been tested at low speeds. Ever. The Earth orbits the Sun, the Sun orbits a supermassive black hole, and the Milky Way galaxy as a whole is accelerating away from other galaxies toward the Great Attractor.
  • Skeptical
Purge said:
Lorentz Invariance has never truly been tested from a "zero-velocity" reference frame.
Suppose you were given a capable spaceship in which to fly that contains whatever test equipment you desire. How would you maneuver that vehicle to achieve "zero velocity"? What measurements would you make to verify that you really were in that exact reference frame?
Speed and acceleration are not the same. Please use accurate terminology.
Can you quantify "low speed"? The Milky Way is moving toward the Great Attractor at less than 0.2% of light speed. How low do you have to go to be satisfied?
That's why I put "zero velocity" in quotes. It is difficult to define what "zero velocity" truly is, so physicist typically use the rest frame of the CMB.
As for speed, it doesn't necessarily have to be low to test for Lorentz Invariance. The key is that the test be conducted from a true inertial reference frame. I was simply pointing out that tests conducted so far are all at relativistic speeds (significant relativistic corrections).
  • Skeptical
An inertial frame is not defined in terms of speed, it is characterized as having zero acceleration. And that's true in both Newtonian and relativistic physics; i.e., any frame moving at any uniform velocity is inertial. So I think you argue from a misconception.
That's because there is no such thing.
If it's vacuum, it doesn't have a preferred frame. That's part of the definition of "vacuum"--that it has no preferred state of motion.
Relative to what?
There are plenty of papers in the literature about hypothetical models along these lines. If you want to discuss one, please start a new thread and give the paper you want to discuss as a reference.
Nonsense. Practically everything on Earth itself is moving at "low speeds" relative to other things on Earth. We all effectively run thousands of tests of the validity of the low speed approximation of our best current physical theories every day as we go about our daily business. And of course physicists have done many such tests to much higher precision.
This demonstrates a fundamental misunderstanding of relativity - even Galilean relativity. There is no such thing as an absolute zero velocity. In fact, if there were then that in itself would imply Lorentz violation.
That doesn't make a lot of sense. Lorentz invariance doesn't need to be tested from a "zero-velocity" frame. What specific experiment do you think depends on being tested from a “zero-velocity” frame?
When SR is tested we use a test theory. The test theories don’t require that the frame of the test be a “zero velocity” frame, but they are able to distinguish whether such a frame exists or not through their parameters.
If such a frame existed then we could measure that it exists and how fast we are moving with respect to it, based on the parameters of the test theory that we measure.
It is not necessary to test in a true inertial frame either. Most valid tests of relativity are insensitive to the acceleration. Those that are sensitive to it simply measure it and account for it.
You are putting in meaningless restrictions. There no test theories or alternate theories that require such tests.
As an exercise, pick an experiment and pick a test theory. Determine the relevant parameter for the test theory and calculate its value under the assumption that the apparatus is moving at velocity ##v##. Find the value of the parameter that corresponds to special relativity, and see if it depends on ##v##.
In addition to what others already told you, it seems that you don't even understand the difference between acceleration and velocity.
  • · Replies 20 ·
