Lorentz Transform Derivation questions
The discussion centers on the confusion surrounding the derivation of the Lorentz Transformation, particularly in understanding the meaning of the equations x' = ax - bct and ct' = act - bx. The author struggles with the concept of x' representing the position of light in the K' frame and the notion of "permanence" at the origin of K'. There is uncertainty about whether x' changes meaning or if the notation is inadequate, especially regarding the conditions under which the equations apply. The author questions how the derived equations relate to the motion of the K' frame and whether all conditions from previous equations must be satisfied. Ultimately, the x' coordinate is defined by distances measured from an inertially moving object at rest in the K' frame.
kwestion
I'm trying to follow along with Simple Derivation of the Lorentz Transformation, but am having some hurdles.
I'll be referring to step (5) which states:
x'=ax-bct
ct'=act-bx​
In paragraph marked 6, I see that the author tries to get eqn (5) to describe motion of the K' frame. This is an important move, but not understood. Up until that point, I believe x' has been a description of the position of light on the frame K' with x' having rules of motion that include x'=ct'. x'=ct' suggests to me that x' is at the K' origin for only a moment when t'=0, but the author states that:
For the origin of k' we have permanently x' = 0[...]​
I don't understand the "permanence" here. Does x' linger at the K' origin? Did x' change meaning? Is it poor notation? Is it that since t'=0 is the only valid moment* for (5) that the state of that moment constitutes a permanent state for (5)? Is there a better description of why (5) begins to be used to track the motion of the frame? I don't see how the position of x' helps understand the movement of K' here. * "The only valid moment" is an unconfirmed assumption on my part. (5) was derived from equations like x-ct=0 and x+ct=0 (inferred) and x'-ct'=0 and x'+ct'=0 (inferred). Upon combining equations in (5), I think all former conditions need to be satisfied by any x, t, x', or t' used with (5). That is, valid x,t,x',t' must not contradict any of: x-ct=0, x+ct=0, x'-ct'=0, or x'+ct'=0, which implies that x=0, t=0, x'=0, and t'=0. What perspective am I missing?
This is just a matter of definition. The x' coordinate in the frame K' is defined by measuring distances from some inertially moving object that is at rest in the K' frame.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 54 ·
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 101 ·
  • · Replies 33 ·
