Using Maclaurin Polynomials to Evaluate Trigonometric Functions at f(0.1)
The discussion revolves around evaluating trigonometric functions using their third Maclaurin polynomials at f(0.1). The user initially struggles with the calculations for the functions f(x) = (x cos x - sin x) / (x - sin x) and provides derivatives to find the polynomial approximations. A key correction is noted regarding the use of only the first two terms of the Maclaurin series for cosine and sine functions, which simplifies the process. After applying this correction, the user is able to resolve the problem effectively. The conversation highlights the importance of accurately applying polynomial approximations in calculus.
francisg3
I am having some difficulty with a homework problem I was recently assigned. The problem says to "Replace each trigonometric function with its third Maclaurin polynomial and then evaluate the function at f(0.1)"
This is what I have done so far:
f(x)=(x cosx- sinx)/(x-sin⁡x)
1st trig function f(x)=x cos⁡x
f'(x) =cos⁡x-x sin⁡x
f''(x) =-sin⁡〖x-sin⁡x-x cos⁡x 〗
f'''(x) =-cos⁡〖x-cos⁡x-cos⁡x 〗+x sin⁡x f'''(0) =-3
3rd Maclaurin Polynomial-3/3! x^3
2nd trig functionf(x)=-sinx
f'(x)=-cosx
f''(x) =sinx
f'''(x) =cosx = f'''(0) =1
3rd Maclaurin Polynomial(1/3!) x3
Replacing those values in the original function I get:
(-3/3! x^3+1/3! x^3)/(1+1/3! x^3 )
I should get an answer around -2 I believe however this is not the case. Any help would be appreciated.
Thanks!
f'(x)=-cosx
f''(x) =sinx
Thanks!
Hi Francis.
I put in bold an important instruction in the above quote.
\cos(x)=1-\frac{x^2}{2}+\frac{x^4}{4!}-\dots
\sin(x)=x-\frac{x^3}{3!}+\frac{x^5}{5!}-\dots
f(x)= \frac{x \cos(x)- \sin(x)}{x-\sin(x)}
You probably meant third degree MacLaurin polynomial, in which case, use only the first two terms in each of the above.
it works, thank you very much.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
22K
