Maclaurin Series, expressing 2^x as a M series.
The discussion focuses on expressing the function 2^x as a Maclaurin Series by utilizing the properties of logarithms and exponential functions. The key insight involves rewriting 2 as e^{ln 2}, transforming the function into e^{(ln 2) · x}. This allows for the application of the Maclaurin series for e^u, facilitating the derivation of the series. Additionally, the differentiation rule for exponential functions is derived, confirming that the nth derivative of a^x is (ln a)^n · a^x.
  • Understanding of Maclaurin Series
  • Familiarity with exponential functions and their properties
  • Knowledge of logarithmic transformations
  • Basic differentiation rules, particularly the Chain Rule
  • Study the Maclaurin Series expansion for e^u
  • Explore the properties of logarithms in relation to exponential functions
  • Learn about the differentiation of exponential functions, specifically the rule for a^x
  • Practice deriving Maclaurin Series for various exponential functions
Mathematicians, students studying calculus, and anyone interested in advanced series expansions and differentiation techniques.
Disowned
Okay I was given this problem as a challenge question. It simply says expressing 2x power as a Maclaurin Series. At first, following an example given by my instructor, I thought that by examining the function as I took multiple derivatives I could find a pattern.
By as you can imagine taking multiple derivatives of an exponential function is anything but pretty. So instead I thought to express the function as a logarithm and set 2x = n, from there I could rewrite it as Log2 n = x. But I'm having trouble visualizing that as a sum at 0 to infinity. Anyone got any hints?
Well, taking higher derivatives of a^x isn't all that awful... but there is a short cut.
Write 2 as e^{ln 2}. Then our function becomes
y = 2^x = (e^{ln 2})^x = e^{(ln 2) \cdot x}
using properties of exponents. (This is a fairly standard "trick".)
Now call u = (ln 2) · x and use it in the Maclaurin series for e^u.
THAT. IS. BRILLIANT! Thank you, I can use this info.
Yes... yes, it is rather... not that I invented the idea...
The same trick is used to obtain the rule for differentiating exponential functions:
\frac{d}{dx} a^x = \frac{d}{dx} (e^{ln a})^x = \frac{d}{dx} e^{(ln a) \cdot x}<br /> = (ln a) \cdot e^{(ln a) \cdot x} [by the Chain Rule]
= (ln a) \cdot a^x
(a useful differentiation rule to remember; you can see immediately that it gives \frac{d}{dx}e^x = e^x as expected)
So, by extension, we have for f(x) = a^x ,
\frac{d^n}{dx^n} a^x = (ln a)^n \cdot a^x
which would also give you the Maclaurin series you were after.
  • · Replies 38 ·
  • · Replies 16 ·
