Magnet moving over surface creating levitation
The discussion revolves around the concept of magnetic levitation using Halbach Arrays and the Inductrack system. Participants explore the mechanisms by which a moving magnet induces electric currents in a metal track, leading to levitation. The focus includes theoretical underpinnings, such as Lenz's Law, and the implications of the induced magnetic fields.
  • Some participants discuss the role of Halbach Arrays in generating repulsive forces when moved over a surface, questioning the mechanism behind levitation.
  • One participant clarifies that Halbach Arrays create a magnetic field that can induce eddy currents in a metal track, which then produce an upward magnetic field.
  • There is a query about why the induced magnetic force results in levitation rather than attraction, with a suggestion that Lenz's Law may play a role.
  • Another participant notes the historical context of the Inductrack system and references various articles and patents related to its development.
  • Some participants express uncertainty about the workings of the system and the lack of thorough explanations in previous discussions.
Participants express differing levels of understanding regarding the mechanisms of levitation and the role of eddy currents. There is no consensus on the explanation for why the force is repulsive rather than attractive, indicating ongoing debate and exploration of the topic.
Participants acknowledge the complexity of the topic, including the dependence on definitions and the need for further clarification on the principles involved, such as Lenz's Law and the behavior of magnetic fields in this context.
vidur27
Hi,
I've been doing reading on Halbach Arrays moving over surfaces and generating repulsive forces. From my understanding, the moving magnet induces a circular electric current in the metal track, which gives rise to a magnetic field.
However, I'm having trouble understanding why this field causes the array to levitate. Why doesn't the array become attracted to the sheet?
hi there
welcome to PF :smile:
vidur27 said:
Hi,
Im not sure what you are describing is really a Halbach Array. Have you read the wiki article ?
https://en.wikipedia.org/wiki/Halbach_array
A Halbach array is a special arrangement of permanent magnets that augments the magnetic field on one side of the array while cancelling the field to near zero on the other side.[1] This is achieved by having a spatially rotating pattern of magnetisation.
The rotating pattern of permanent magnets (on the front face; on the left, up, right, down) can be continued indefinitely and have the same effect. The effect of this arrangement is roughly similar to many horseshoe magnets placed adjacent to each other, with similar poles touching.
Dave
Sorry, I was on my phone, I should be a little more detailed.
There exists a system called the Inductrack where they essentially move a halbach array at a velocity over a track. This induces circular eddy currents in the track, which in turn produce an upwards magnetic field. In theory, the upwards magnetic field causes the halbach array to levitate over the track. Because the strength of the field is proportional to the strength of the current which is proportional to the rate of change of magnetic flux from the array over time, the faster the array moves over the track, the greater the levitative force will be.
My question is a fundamental one. So we induce eddy currents in the track, which gives rise to eddy currents, which gives rise to a magnetic force in the "upwards" direction. Why is this force a cause for levitation (repulsion) and not attraction? Is it a consequence of Lenz's Law? I'm having trouble seeing it!
Interesting. I have no idea how it works.
It appears to have been invented at the Lawrence Livermore National Lab.
Here's an article dated 1998.
There have been a few discussions about it here at PF. I don't see anywhere that anyone thoroughly explained the effect.
It appears to still be in the testing phase.
The original patent:
Magnetic levitation system for moving objects [google patents]
US 5722326 A
publication date March 3, 1998​
Here's a paper by the inventor, Richard Post:
The Inductrack Approach to Magnetic Levitation
POST, Richard F., RYUTOV, Dmitri D.
Lawrence Livermore National Laboratory​
  • · Replies 17 ·
