Magnetic field at center of coaxial loops
4 replies · 2K views
hidemi
We find that N current loops are coplanar and coaxial. The first has radius a and current I. The second has radius 2a and current 2I, and the pattern is repeated up to the Nth, which has radius Na and current NI. The current in each loop is counterclockwise as seen from above. The magnitude of the magnetic field at the center of the loops is:
a. µoI/2Na
b. µoI/Na
c. µoI/2a
d. µoNI/2a
e. µoNI/a
Ans: D
B = µoI/2a
I calculate like this and I think the answer is E not D.
N( µoI/2a + µo2I/2*2a)
= 2µoNI/2a
= µoNI/a
For N=1, d, not e, gives the relevant equation you wrote.
Thanks for reply.
Here's my calculation:
= 2µoNI/2a
= µoNI/a
The question is asking about the two loops combine. The relevant equation does not include the two loops.
You have misread the question. The question is about N loops. N could be any integer, 1, 2, 3, 4, 5 ...
For example if N=3.
First loop has radius = a, current = I, its field is ##B = \frac {\mu_0 I}{2a}##
Next loop has radius = 2a, current = 2I, its field is ##B = \frac {\mu_0 (2I)}{2(2a)}##
Next loop has radius = 3a, current = 3I, its field is ##B = \frac {\mu_0 (3I)}{2(3a)}##
For example if N=3.
Ok, I see where you are getting.
Thank you so much.
