Magnetic Field, Biot-Savart Law & Current-carrying Wire
The problem involves calculating the magnetic field at a point P due to a current-carrying wire, specifically considering a semicircular segment and two infinitely long wire segments. The context is rooted in the application of the Biot-Savart Law.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the magnetic field from the semicircle and questions the contributions from the straight wire segments, considering their potential cancellation. Participants discuss the correct setup for the vector expressions involved in the calculations and the implications of sign conventions.
Participants are actively engaging in clarifying the setup of the problem, particularly the vector components involved in the calculations. Guidance has been offered regarding the application of the right hand rule and checking signs in the expressions, with some participants indicating that the original poster's calculations are largely correct aside from specific sign issues.
There is an emphasis on ensuring the correct interpretation of vector directions and signs, which is critical for the calculations involved in applying the Biot-Savart Law. The discussion reflects a collaborative effort to refine the original poster's understanding of the problem setup.
Sudharshan
A current I carried in a conduit as described below. The wire can be assumed to be infinitely long in the positive x-direction. The point P is the radius distance a from the portion of the line that describes a semicircle. Calculate the resulting magnetic field at point P in magnitude and direction.
Biot-Savart Law:
I have calculated the magnetic field caused by the semicircle. I am not quite sure how to calculate the magnetic fields caused by the two infinitely-long wire segments. From my calculations they cancel each other out. Is this correct? Is the magnetic field caused by the semicircle correct?
I have linked my answer below:
Page 1:http://i.imgur.com/sPh6NiO.jpg
Page 2:http://i.imgur.com/YOSuQ95.jpg
Page 3:http://i.imgur.com/wL1DCmv.jpg
Any help is appreciated.
Hello, Sudharshan.
You should be able to decide if the fields of the two straight line segments cancel by using the right hand rule for the direction of magnetic field of a straight section of wire.
Check your signs when setting up the expression for ##\vec{r} - \vec{r}'## in the calculation of the field of L1.
Otherwise, your calculations are very nice and complete!
Hey TSny,
Does this mean my BL1 is incorrect which leads to the fact that my total magnetic field B is incorrect? Can you specify what mistake you have found? When I calculated BL1 I was unsure about the signs of r and r'.
The only mistake that I see is in your expression for ##\vec{r}-\vec{r}'## for L1. In particular, what is the sign of the y component of ##\vec{r}##?
That was the sign I was not sure about. I had written r = ay. Should it not be r = a(-y) because it points in the negative Y direction hence the negative sign?
This should mean that the fields of the two straight line segments do not cancel each other because they point in the same direction with the help of the right hand rule (point towards I with thumb and curl fingers in direction of B).
Yes. See the attachment
So it is only that negative sign that is wrong ? Do you see any other mistakes in the rest of the answer?
Ok, I will do this change and rewrite my answer. It would be great if you could take another look then and let me know if it is correct. Thanks again for all your help.
Looks correct. Nice work!
Thank you.
  • · Replies 0 ·
