Are Particles Responsible for Magnetic Field Frequencies?
The discussion revolves around the nature of magnetic fields, particularly in the context of permanent magnets, and whether particles such as photons are responsible for magnetic field frequencies. Participants explore concepts related to electromagnetic fields, the composition of fields, and the relationship between particles and fields.
  • Some participants question whether photons flow from one end of a permanent magnet to another and what determines their frequency.
  • Others assert that the magnetic field is not composed of particles, describing it as an independent entity that exists on its own.
  • One participant emphasizes that electromagnetic fields are a combined, inseparable entity, suggesting that electric and magnetic fields are manifestations depending on the observer's perspective.
  • A participant provides a technical explanation of magnetic fields in permanent magnets, referencing "bound surface currents" and their relation to the magnetization of the material.
  • Some participants challenge the adequacy of engineering approximations in explaining the generation of magnetic fields, suggesting that additional effects like the exchange effect are necessary for a complete understanding of ferromagnetism.
  • There is a philosophical inquiry into whether a field can exist without particles, with some participants asserting that particles are states of quantum fields rather than the other way around.
Participants express multiple competing views regarding the nature of magnetic fields and their relationship to particles. The discussion remains unresolved, with differing opinions on whether fields can exist independently of particles and the adequacy of various explanations for magnetic phenomena.
Some claims rely on specific definitions and assumptions about fields and particles, and there are unresolved questions about the nature of fields in the absence of particles.
Mediocrates
So are there photons "flowing" from one end of a permanent magnet to the other? If so what determines the frequency?
No, and that makes the second part moot.
Of what then is the field composed?
Nothing. Field is a field, entity that lives on it's own. Photons are "excitations" (whatever that means) of quantum electromagnetic field, but that doesn't justify the claim that em field is composed of anything.
There was another thread just yesterday that veered off massively, so I think it's worth pointing out that "electromagnetic" isn't just a convenient moniker to refer to the magnetic and electric field together, but rather that they are really are one combined, inseparable entity. That is, the classic "electric field" and "magnetic field" are manifestations depending on the observer, and indeed different observers might entirely disagree on whether a certain action was caused by an electric field, or a magnetic field.
For the OP @Mediocrates The best simple explanation for the source of the magnetic field in a permanent magnet=[e.g. a cylindrical magnet with uniform magnetization vector ## \vec{M} ##,(that points from the "-" end to the "+" end), that essentially has a "plus" (north) magnetic pole on one endface and a "minus" (south) magnetic pole on the other endface], is the explanation of "bound surface currents" from the magnetization that "circulate" around the outer cylindrical surface with the same geometry as that of the currents of a solenoid. Since these currents are the resultant edge effect of what could be viewed in a simplistic model as currents from the magnetic moments of individual atoms, there is no actual electrical charge transport from these currents. In any case, the magnetic field ## \vec{B} ## of the permanent magnet, both inside and outside the magnet can be computed from these hypothesized "surface currents" using Biot-Savart's law, and the results are consistent with the magnetic field that is observed.
@Charles Link , that is an engineering approximation that hardly elucidates the actual generation of the magnetic field in a permanent magnet.
The exchange effect is an additional effect necessary to explain ferromagnetism, but the magnetic surface currents can be quantified with what I believe are highly accurate results. For a simple calculation, see the following post: https://www.physicsforums.com/threads/magnetic-field-of-a-ferromagnetic-cylinder.863066/ Hopefully this doesn't start to lead too far off topic before the OP gets a chance to respond. ## \\ ## Also, Griffith's Electrodynamics book contains a very good derivation of the surface currents as he computes the vector potential ## \vec{A} ## from an arbitrary distribution of magnetization ## \vec{M} ##. I believe this result is in section 6.2 of his book.
Charles ... you are making this far more complex than what a B level topic should be :smile:
How would one determine the existence of a field in the absence of particles?
That's probably more of a philosophical question since that scenario wouldn't be our universe.
Quess my question was, "can there be a field without a particle?" I thought particles give rise to fields?
No it's the other way around, particles are states of (quantum) fields.
  • · Replies 0 ·
  • · Replies 16 ·
