Magnetic field from two parallel current-carrying conductors
9 replies · 2K views · last reply
physics=world
Two long parallel conductors carry currents I_1 = 3.0A and I_2 = 3.0A, both directed into the page. Find the magnitude and direction of the resultant magnitude field at point p?
I need help with this problem. The professor only provided the answer but not the steps. I'm having a hard time understanding what to do. I can do all the other problems, but when it comes to a problem like this (with having to apply vectors) I do not know what to do. Help me.
First I tried drawing the magnetic fields (figure 2). Then I found the angles - 23 degrees and 67 degrees.
I am stuck after this. How do I solve using vectors?
  • Diagram of a right triangle with two wires marked by crosses (into the page) at the upper-left and bottom-left corners and point P at the right corner. Sides: I_1 to P 5.0 cm, I_1 to I_2 13.0 cm, I_2 to P 12.0 cm; right angle at P.
The B field around a wire follows circles - at distance r, the B vector will be a tangent to the circle, centered on the wire, with radius r.
Is ##\vec{B}_1## the field due to ##I_1## and ##\vec{B}_2## the field due to ##I_2##?
If so, they are pointing in the wrong directions. Please see the accompanying link.
oh yes, I am sorry. your correct. i miswrote the B1 and B2.
hmm is the special right triangle the triangle with the 90 degrees or is it the one with the added vectors?
i know how to add vectors like moving head to tail, but not very well when it comes to the math.
so at this point i would get a resultant vector that goes straight down. but I am confuse. do i do the x and y component for B1 and B2 separately or do i do the x and y component for the resultant component?
To use x-y components you need to define an x and y-axis - which is not provided for you.
Instead you should use the head-to-tail triangle of vectors and your knowledge of trigonometry.
One special triangle you have is the pythagorean triplet 5-12-13 ... point P is at the right angle.
It is probable that the B vectors also make two sides of a special triangle. They do conveniently make a right-angle with each other. If the resultant vector does go straight down, then it must be 5-12-13 as well.
There are lots of ways of specifying the direction of a vector.
If you label the position of I1 as Q and I2 and R, then the straight down direction is the Q-R direction ... or "parallel to ##\overrightarrow{QR}##"
