diethaltao
- 14
- 0
A solid cylindrical conducting shell of inner radius a = 5.3 cm and outer radius b = 7.9 cm has its axis aligned with the z-axis as shown. It carries a uniformly distributed current I2 = 7.1 A in the positive z-direction. An infinite conducting wire is located along the z-axis and carries a current I1 = 2.7 A in the negative z-direction.
What is [itex]\int[/itex][itex]^{P}_{S}[/itex] [itex]\vec{B}[/itex] . [itex]\vec{dL}[/itex], where the integral is taken on the straight line path from point S to point P as shown?
Link to the picture: http://i89.photobucket.com/albums/k211/diethaltao/h15_cylindersD.png
I'm not even sure how to approach this problem. At first I found the difference between the values of the magnetic field at P and at S, but this was wrong.
Then I thought to use
∫[itex]\vec{B}[/itex] . [itex]\vec{dL}[/itex] = μoI
but B is not constant over the interval [S,P] so I can't pull it out of the integral.
I was able to calculate the integral along the dotted path in the picture, which I basically did by realizing R to S was perpendicular to the field so it didn't count, and that P to R was 1/8 of a larger circle drawn around the diagram. But in this case, B was a constant distance from the centre.
Any input is appreciate. Thanks!
