Magnetic force -- does it fall off to zero far away from the source?
The discussion centers on the behavior of magnetic fields generated by a closed circuit and their propagation speed, specifically at distances far from the source. Participants emphasize that the magnetic field is part of an electromagnetic field, which can be described using the Lienard-Wiechert potentials, a solution to Maxwell's equations for moving charges. The conversation also touches on the limitations of Maxwell's equations, noting that they do not encompass gravity or quantum phenomena, and the emergence of contradictions when applying Galilean transforms instead of Lorentz transforms in the context of relativity.
  • Understanding of Maxwell's equations
  • Familiarity with electromagnetic fields and their properties
  • Knowledge of Lienard-Wiechert potentials
  • Basic principles of Special Relativity and Lorentz transformations
  • Study the Lienard-Wiechert potentials in detail
  • Explore the implications of Maxwell's equations in different reference frames
  • Investigate the relationship between electromagnetism and quantum theory
  • Learn about the historical context and debates surrounding the ether theory
Physics students, educators, and researchers interested in electromagnetism, the foundations of modern physics, and the interplay between classical and quantum theories.
Yahya Sharif
Let's say we have a wire and a circuit is closed the magnetic field start to spread with speed of light c. Then we would have a place " out of range " at which the magnetic field doesn't exist.What is the equation that connects magnetic force with distance with its prorogation of speed of light c and with its range ?
Actually, it'll be an electromagnetic field, not a pure magnetic field.
You need to look up the Lienard-Wiechert potentials, which describe fields from general moving charges. The maths is not simple, I'm afraid.
haha I am in physics II right now and this totally blew my mind. We just learned about Maxwell's equations and now I learned they have some sort of contradiction and they still don't describe everything. Thanks
I'm afraid I don't understand this comment. There are no contradictions that I'm aware of, and the only thing Maxwell's equations don't cover in electromagnetism is quantum theory.
Edit: The Lienard-Wiechert potentials, if that's what you are referring to with "don't describe everything", are a solution to Maxwell's equations for a particular scenario.
ok i wasn't sure to the inclusivity about the Lienard-Wiechert potentials but I was referring to how in the article it talks about how there's a problem with maxwell's equations and linearity?
khamo said:
in the article
Which article? People here can better address the problems or contradictions that it discusses if they can actually read it for themselves.
Guessing at the meaning...
Maxwell's equations by themselves are self-consistent. No contradictions. But if you add the principle of relativity (the laws of physics are unchanged regardless of the choice of inertial reference frame) and if you try to transform measurements between frames using the Galilean transforms then contradictions emerge.
One way out is to hypothesize a medium against which electromagnetism operates -- the ether. Another way out is to use the Lorentz transform and discard the notion of absolute time. The result is Special Relativity.
Maxwell's equations do not describe everything. They do not describe gravity, the strong nuclear interaction, or the photoelectric effect.
Right i guess that was the general point i was alluding to.
I actually misinterpreted what i was reading. What i meant to say was that 'linearity of Maxwell's equations in vacuum allows one to add both systems, so that the charges disappear'.
which is kind of like a contradiction? what are the 'systems' they are talking about?
  • · Replies 20 ·
  • · Replies 61 ·
