Is There a Relationship Between Dipole and Wire Interaction Energy?
The discussion centers on the relationship between dipole interaction energy and wire interaction energy, specifically addressing the equation $$m=QR\omega \hat{z}$$ and the derived expression for the vector potential $$A_{dip}=\frac{\mu_0}{4\pi}\frac{QR\omega}{r^2}\hat{\phi}$$. The user seeks clarification on how to relate the vector potential A to the interaction energy between a dipole and a wire. The recommended approach includes using the approximation for large distances (r >> R) and applying the formula for potential energy, $$U= -m.B$$, where B represents the magnetic field.
  • Understanding of magnetic dipoles and their properties
  • Familiarity with vector potentials in electromagnetism
  • Knowledge of magnetic fields generated by current-carrying wires
  • Proficiency in Taylor series expansion for approximations
  • Study the derivation of the magnetic field from a straight wire using Ampère's Law
  • Explore the concept of magnetic dipole moment and its applications
  • Learn about the Taylor expansion method in the context of electromagnetic fields
  • Investigate the interaction energy between two magnetic dipoles for comparative analysis
Physicists, electrical engineers, and students studying electromagnetism, particularly those interested in the interactions between magnetic dipoles and current-carrying conductors.
Diracobama2181
A sphere of radius R carries a charge q that is distributed uniformly over the
surface of the sphere. The sphere spins at constant angular velocity ω.
(a) Calculate the magnetic moment m of this sphere and determine the leading
term of the multipole expansion of the vector potential A at large distances
r : i.e., r >> R.
(b) Calculate the interaction energy between this sphere and an infinite straight
wire carrying a steady current I. The angle between the direction of the
current and the angular velocity vector ω is θ while the distance ρ between the wire and the sphere is much greater than the sphere radius: i.e.,
ρ >>R. Consider the case when ω is perpendicular to ˆe_ρ.
$$m=\int I da$$
$$A_{dip}=\frac{\mu_0}{4\pi}\frac{msin\theta}{r^2}$$ (from Griffiths)
Part a was not much of a problem. I got that $$m=QR\omega \hat{z}$$. From that, I get $$A_{dip}=\frac{\mu_0}{4\pi}\frac{QR\omega}{r^2}\hat{\phi}$$ (using $$\theta=\frac{pi}{2}$$.
My problem occurs in part b. I know there is a potential energy relation for two dipoles, but what would I use for a dipole and a wire? More specifically, is there a relationship between A and the interaction energy? Any suggestions or further readings on this subject would be appreciated. Thank you.
Try using approximation r>>R. The magnetic field is approximately constant over the surface. Or you can be more exact if you Taylor expand the magnetic field due to wire at large distance. After that use:
## U= -m.B##
