cmos said:
This is actually misleading or even wrong.
At the risk of getting off topic:
B is the fundamental magnetic field quantity. It is the only magnetic field that appears in the
http://www.google.com/url?url=http:...NoTeGjD4zksQOCt_mmBA&ved=0CCMQygQwAA&cad=rja". H is a derived field; it arises as a form of convenience when dealing with the magnetization of materials.
However, we can, & do, drive magnetic components w/ either a voltage source or a current source. An inductor is often excited with a dc bias in the form of a current source (or a voltage source plus a resistance, which is the equivalent). Here, H is fixed, & B is determined by the H value & core material. H is independent, B is dependent.
I'm not sure about this one. Can you please explain how having a voltage source would make B independent?
You cite "Wikipedia" as a reference that B is more basic than H. Even high school students studying at the AP level are informed that Wiki alone is not a credible reference. Students who rely solely on Wiki, w/o corroberation, are given an F grade.
Second, notice the equation from Maxwell "curl H = J + dD/dt." In Wiki, it is expressed as "curl B = mu*J +..." Any Maxwell equation can be expressed using H or B, E or D. It's just a matter of making use of the fact that D = epsilon*E, & B = mu*H.
For Ampere's Law, the most basic form is "curl
H = J + dD/dt", where J is conduction current, & dD/dt is displacement current. Hence the relation between conduction current & mag field is most basic in J & H. In other words, for a given J in a conductor, there is a specific value of H. This H value is totally independent of medium. The B value however, depends on the medium since B = mu*H. Thus for a current density J, H is determined solely by J, but B is determined by J as well as Mu, the permeability of the medium.
The fact that you have to be told this demonstrates that you don't know enough to be rebuking others. The fact that H is independent of medium, while B is dependent, is spelled out in any good fields text. Have you had e/m fields at the engr or phy level?
I'm not attacking your intelligence. I just can't understand how you can even imagine that all the uni e/m texts are wrong, & that you have knowledge the science community lacks. I worked in inductive component design for several years, & since then have branched out into general EE, but still do mag work.
The fact that B& H are mutual & neither is more basic has been reaffirmed by science, relativity, Maxwell, EE community, magnetic material producers, etc. These are the experts. You, OTOH, take an excerpt from Wiki, the crackpot center of the world, give it your own narrow interpretation based on your preconceived preferences, & run with it.
Wiki is not only unreliable. But they didn't even say what you claim they said.
Regarding your last question, here it is. Faraday's Law, FL herein, says that V = -N*d(phi/dt). The flux is "phi", & the flux density, flux/area = weber/m^2 or tesla, is "B". So, A*B = phi, where A = area.
Thus V = -N*A*dB/dt. If the primary of an xfmr is connected across a good constant voltage source, CVS herein, then V, the voltage is forced to be constant. Since N the turns number, & A the area, are fixed, & V is fixed, then dB/dt is determined solely by V, the voltage value of the CVS. Since V is usually a sine function, dB/dt will be a cosine, multiplied by radian frequency.
Thus the magnitude of B is determined by voltage V & frequency omega, as well as A & N. H, however, is determined by the mu of the core material. A high mu material, is subjected to the same V & B as a low mu material. The higher mu core incurs a lower H value than the low mu core, & hence lower magnetizing current.
Depending on how a magnetic device is excited, H could be independent of the material, w/ B dependent on mu, or vice-versa. As I said, based on decades of experience & study, they are inclusive. Neither is fundamentally more basic, they co-exist in unison, neither being the cause nor the effect. We can, however, drive magnetic devices in different manners. We can force H to be constant w/ B dependent, or the other way around. Just as a forced H & given mu determines B, a forced B & given mu can determine H.
It works both ways. Did I make it clear. I'll gladly elaborate if you wish.
Claude
