Magnets in Cars-Coils in Roads
  • Context: Undergrad
  • Thread starter Thread starter ruko
    Magnets
Magnets in cars passing over coils in roads generate power, but this process is not free energy. The energy transferred to the coils comes from the additional fuel burned to overcome the resistance created by the interaction between the car's magnets and the coils. This resistance arises from the induced current generating a reverse magnetic field, opposing the motion of the car's magnet. Implementing such systems at stop lights or freeway exits may improve efficiency, but the overall energy recovery remains limited and commercially unviable due to high infrastructure costs and low efficiency compared to dedicated power generation facilities.
  • Understanding of electromagnetic induction principles
  • Knowledge of energy conversion and efficiency metrics
  • Familiarity with regenerative braking systems in hybrid vehicles
  • Basic concepts of electric generators and magnetic fields
  • Research the principles of electromagnetic induction and its applications
  • Explore the efficiency of regenerative braking systems in hybrid and electric vehicles
  • Investigate the economic feasibility of energy recovery systems in urban infrastructure
  • Learn about the design and operation of electric generators and their efficiency ratings
Engineers, urban planners, automotive designers, and anyone interested in energy recovery technologies and their practical applications in transportation systems.
ruko
Magnets in cars passing over coils in roads would definitely generate power. There are a few people who think this would be free power. I don't know how to properly explain why it would NOT be free power. Can someone help?
The energy transferred to the coils would come from extra gas burned to overcome the extra resistance to motion. You are correct, there is no free energy.
Just to be clear, would this resistance come from the attraction of the car's magnet to the coil? Or is it that the coil is resisting the 'charging' by the car's magnet (it comes from relative motion)? Or both?
Just as in a regular rotating generator, the current that is induced in the coil generates a reverse magnetic field that opposes the field that is inducing the current. This makes a resistance to the motion of the exciting magnet. That's why there is resistance to rotation of a rotating generator, when there is a load connected to its output.
http://en.wikipedia.org/wiki/Electric_generator
What if you put them at stop lights or freeway exits or similar places where people are slowing down anyway? It's not free energy, but would it be 'more efficient' energy?
I saw a segment on the BBC a while back where someone had designed a speed bump that "produced" energy, i.e. the energy that would normally be dissipated by breaking the car was somehow turned into electricity when the car drove over it.
I very much doubt it would be commercially viable, but it was a nice idea.
Also, there are already all sorts of techniques for recovering energy from cars that are slowing down, most(all?) hybrids use regenerative breaking which does exactly that.
In addition to f95's comments, remember that adding weight to a car requires burning more fuel. The speedbump idea would be more efficient, though not much fun for the cars.
Think about electricity as marbles in a tube- you push on the marble on one end, and almost instantly the marble on the other end moves. You could put a match box on the end of the tube and you can still easily push the marble- but it is a little harder to do, but that is work performed.
It is really the same thing, Voltage represents a difference in pressure (charge to be specific)- the pressure of electrons (and protons- but they aint budging, unless your talking about inside a plasma field (like a neon sign)) You have one wire with high pressure (dangerous) and one wire with low pressure (less dangerous and depending on design totally safe) but in reality they are both the same wire- just different ends.
When a magnet passes over say a coil a copper wire- that magnetic field pushes the electrons in the same direction. In the direction it travels becomes the side which is now under higher pressure. In order to make anything under pressure takes some oomph- and that oomph is energy required which will mean more gas is needed to drive the same distance at the same speed.
Then you have to factor in efficiency- a car is 20-30% efficient, it has to be able to operate in all sorts of ways- sometimes you have to hit the gas to get on the highway, sometimes you are backing out of your driveway- and you don't want to wait 2 hours for your car to warm up. A power generation facility is designed to run one way- optimally their engines are not changing rpms- there is no need for transmissions and other energy robbing but vital components for a car which is why they are closer to 80-98% efficient at producing power from fuel.
Also the amount of infrastructure in my opinion would NEVER pay off- by the time the system is rusted and falls apart it will not have produced more energy then it took to construct. Mining ore, refining ore, machining metal takes GREAT deals of energy.
Thanks to all.
  • · Replies 42 ·
