Magnitude and Direction of induced voltage
The discussion revolves around an electromagnetism problem related to the magnitude and direction of induced voltage, specifically involving concepts such as Faraday's Law and Lenz's Law.
  • Participants explore the calculation of induced voltage through derivatives and question the need for constants. There is discussion about the application of the right hand rule for determining current direction and the relevance of magnetic flux in the problem. Some participants express confusion regarding the area involved in the flux calculation and the implications of varying flux density.
Participants are actively engaging with the problem, raising questions about the setup and exploring different interpretations of the laws involved. Some guidance has been offered regarding the application of Faraday's Law and the relationship between magnetic flux and induced voltage, but no consensus has been reached on the specifics of the calculations or assumptions.
There are indications of missing information regarding the measurement of voltage and the shape of the area in question. Participants are also considering the implications of different flux densities across the area involved.
rzn972
Hey everyone I have a physics e&m question: [/B]
http://blob:https%3A//www.physicsforums.com/aa779f37-be23-43d7-a888-d70263a3854b
I took the derivative to find the magnitude of the induced voltage. (do I need to add a constant c?)
I am having trouble with the direction of the current flow though... Do I use the right hand rule?
Thanks![/B]
The constant "c" is usually either the speed of light in a vacuum or the constant of integration ... do either of these situation apply here?
The current flow is determined by the right hand rule in conjunction with a law of physics that applies to induced currents.
I'm puzzled you started at (c) ... did you do (a) and (b)?
4 a) Does the question ask for the magnetic (flux) ?
Oh, it should read the magnitude, not magnetic!
Shouldn't you use Faraday's law?
There might be a small gap in the lower right-hand part of the loop
Well spotted - there may well be.
Sorry! Yeah I meant magnitude.
Okay so the derivative of magnetic flux is the induced voltage. I am having trouble calculating flux. Flux = BA cos (theta). How do I get the area...?
What shape is the area in question?
Ahh I forgot that they gave us the length of the square. I think I was able to get it.
Does this look right?
in (c) and (d) the flux density is different in different parts of the square, how did you account for this?
(hint: the variable y should not be in your answer)
in (b) the question asks for the direction of the current
For b) I say it is counterclockwise. My reasoning is that the field is decreasing as time passes (e^(-t)). The field will want to come out and the way to do that is for the induced current to flow counterclockwise.
I am not clear on c). Doesn't the y variable account for the different flux values for different y values?
11K
15K
