How Do You Calculate Vector Components and Angles in 3D Space?
In summary, the homework statement is that: -The x component,
Neophyte
44
What are
(a) the x component,
(b) the y component, and
(c) the z component of
r= a-b +c if
a = 6.5i + 4.2j - 6.7k,
b = -6.3i + 1.5j + 1.4k, and
c = 8.2i + 4.3j + 5.9k.
(d) Calculate the angle between r and the positive z axis.
(e) What is the component of a along the direction of b?
(f) What is the magnitude of the component of a perpendicular to the direction of b but in the plane of a and b and ?
a . b = abcosθ
c = absinθ
tanθ= (aj/ai)
a) 21
b) 7
c) -2.2
21i + 7j - 2.2k
d)√(441+ 49 + 4.84) = 22.24
θ=sin-1 = 7/22.24
θ = 18.34 /*Incorrect I am pretty sure ;/ */
I took y/r r as hypot and y as opposite
e)Well I know how to find the ay = asinθ etc but the z I do not know.
So I tried
direction of b -i,+j,+k
thus a = -6.5i + 4.2j + 6.7k but then I believe I have three components. So I am clueless.
f) close the book
a X b produces third vector c
i j k
6.5i + 4.2j - 6.7k
-6.3i +1.5j + 1.4k
= 15.93i - 33.11j + 36.21k
= magnitude 51.58
d) You have to find the angle between -z-axis and r, calculate cosθ = z/r, then find (180 - θ ) to find the angle with + z-axis.
so cosθ = 2.2/22.24
θ = 84.3
180 - θ = 95.6 degrees?
If - 2.2k was positive wouldn't it be the same thing as the + z-axis because cos is same for +/-? Will I always do (180 - θ)?
I had done e) wrong
Its basically
a.b = abcosθ
a.b / b = component along direction of b
What is it talking about :cry:
I thought it had something to with
aXb= c = absinθ
But then c is the direction perpendicular to the plan of a and b not in it.
So is a = a; b = c; c=a;
aXc = b = acsinθ
But I don't have the c :\\\\\\\\\\\\
:confused:
e) component of a along b is acosθ = abcosθ/b = a.b/b
1. What is magnitude?
Magnitude refers to the size or quantity of a physical quantity, such as force or velocity. It is typically represented by a numerical value and a unit of measurement.
2. What is a vector?
A vector is a mathematical representation of a physical quantity that has both magnitude and direction. It is typically represented by an arrow with a specific length and direction.
3. How do you calculate the magnitude of a vector?
The magnitude of a vector can be calculated using the Pythagorean theorem, by taking the square root of the sum of the squared components of the vector. Alternatively, it can also be calculated using trigonometric functions, depending on the given information about the vector.
4. What is the difference between magnitude and direction?
Magnitude refers to the size or quantity of a physical quantity, while direction refers to the orientation or angle of the vector. Both magnitude and direction are necessary to fully describe a vector.
5. Why are magnitude and direction important in physics?
Magnitude and direction are important in physics because they allow us to accurately describe and measure physical quantities and their effects. They also help us understand the relationship between different physical quantities and how they interact with each other.
