Magnitude of Force of two point charges on a third (electrostatics)
The discussion focuses on calculating the total electrostatic force exerted by two point charges, q1 = 4.01nC and q2 = 5.00nC, on a third charge, q3 = -6.03nC, positioned at the origin. The formula used is F = (k * q1 * q3) / d^2, where k = 9E9 N·m²/C². The correct approach involves determining the forces F(1 on 3) and F(2 on 3) separately, correcting their signs based on direction, and then summing them to find the net force. The final calculated magnitude of the net force is 2.392E-6 N, rounded to three significant figures.
  • Understanding of Coulomb's Law for electrostatics
  • Familiarity with scientific notation and significant figures
  • Basic knowledge of vector addition in physics
  • Proficiency in using constants such as k = 9E9 N·m²/C²
  • Study vector addition in electrostatics to understand force directionality
  • Learn about the implications of charge signs in electrostatic calculations
  • Explore advanced applications of Coulomb's Law in multi-charge systems
  • Review the concept of electric fields and their relation to forces on charges
Students and professionals in physics, particularly those studying electrostatics, as well as educators looking for practical examples of force calculations involving point charges.
ctallarico20
Two point charges are placed on the x-axis as follows: charge q1 = 4.01nC is located at x= 0.201m , and charge q2 = 5.00nC is at x= -0.301m.
What is the magnitude of the total force exerted by these two charges on a negative point charge q3 = -6.03nC that is placed at the origin?
I know I need to use:
F = (k * q_1 * q_2)/d^2, where k = 9E9
I've tried taking the sum of magnitudes of F(1 on 3) and F(2 on 3), but have been incorrect. I set it up like below:
F(1 on 3) = (k * 4.01E-9 * -6.03E-9) / 0.201^2 = -0.000005 N
F(2 on 3) = (k * 5.00E-9 * -6.03E-9) / 0.301^2 = -0.000003 N
This would give the answer as 0.000008 N, or more precisely 8.37E-6 N. Could anyone tell me where I'm going wrong?
check the sign of F(2 on 3). Which direction is it?
Yeah, it should be positive, my bad. However I've also tried 0.000002 as an answer and that was incorrect:/
Lose the fixed point notation and stick to scientific notation so that significant figures are clear. What's the value of the net force to three significant figures?
F(1 on 3) = -5.387E-6
F(2 on 3) = -2.995E-6
This is a magnitude of 8.37E-6 N, which was incorrect
The first force is wrong (direction).
The second force is okay.
The magnitude appears to be correct though, right? For some reason it's not
Probably because I mixed you up. I suggested F(2 on 3 ) should be +, but it's -. Similarly, F(1 on 3) should be +, not -. But the magnitude of the difference is the same.
Do it gneill's way which is right.
In that case, F(1 on 3) is = 5.387E-6
F(2 on 3) is = -2.995E-6
Magnitude still appears to be 8.37E-6 N like you said. Am I using the wrong equation or something? This doesn't make sense to me
Add the forces, then take the magnitude.
Ohhh I gotcha, so 5.387E-6 + (-2.995E-6), which = 2.392E-6. So the magnitude is 2.392E-6N?
Yup. Round to 3 significant figures for your final result.
Perfect. Thank you all so, so much
