Making a radio that accesses the internet
  • Thread starter Thread starter kennitoster
    Internet Radio
The discussion centers on modifying a Worldspace radio receiver to access the internet for streaming radio without using a PC. Participants conclude that integrating a computer into the receiver is necessary to run a music-playing application, making the project complex and potentially unfeasible. Additionally, it is noted that Worldspace radio is no longer transmitting, further complicating the modification. As an alternative, users are advised to consider purchasing a standalone internet radio device that connects directly to a WiFi modem/router.
  • Understanding of wireless protocols, specifically 802.11 standards.
  • Basic knowledge of computer hardware integration.
  • Familiarity with internet radio streaming technologies.
  • Awareness of proprietary broadcasting limitations, particularly regarding Worldspace radio.
  • Research standalone internet radio devices and their compatibility with WiFi networks.
  • Explore the process of integrating a Raspberry Pi into existing hardware for streaming applications.
  • Learn about digital audio streaming protocols such as RTSP and HTTP Live Streaming (HLS).
  • Investigate the specifications and features of modern internet radios available on the market.
This discussion is beneficial for hobbyists interested in electronics, audio streaming enthusiasts, and individuals considering modifications to existing radio hardware for internet connectivity.
kennitoster
Hi,
I have a Worldspace radio receiver lying around and I listen to internet radio throughout the day using a PC...
I was wondering if there was anyway I could modify the radio receiver and connect it to my modem so that it can access the internet and I can listen to internet radio without leaving the PC on all day!
I am no expert, but your radio is a wireless device. Internet is a digital link that need a lot of protocol. I doubt it is even close to compatible.
Even if it is a wireless internet, I believe it is still running 802.11 format that has it's own protocol. It will be a huge project if it is even possible.
I could be wrong, someone might know more.
kennitoster said:
Hi,
Hmm.. not easy. You would need to put a computer inside the receiver in order to run a music-playing application.
You might be better off with a table top, stand-alone internet radio. There are several around, like
Some table-top internet radio
This thingie costs only $60 (but of course will not have the same sound quality as a PC audio system) and does not require a PC - only a WiFi modem/router.
Disclaimer: these table-top devices require either an Ethernet cable connection to your modem/router, or an existing WiFi network provided by your modem/router. Better check for compatibility before buying one.
Worldspace radio is proprietary broadcast radio and is no longer transmitting. It would be pretty much impossible to connect the device to a network connection to stream internet radio.
Thanks a lot.
I guess I'll just drop this idea.
  • · Replies 37 ·
