Making an Algorithm to Check Whether a Number is a Prime Number
33 replies · 6K views · last reply
I couldn't test it cause the class was in the early morning. But my teacher excepted it so Idk it caused no problem.But for today I have to make 2 more flowcharts...
It's rather sad if the flowcharts you have to write are a lot less clear than the computer program would be. In this case you really want it to be clear in your program for which values of m the trial division is done. if you have
Python:
for m in range (2, n/2):
Code:
for (m=2; m<= n/2; m++)
that should be clear enough. With your pseudocode, or with a flowchart it's not so clear exactly what values of m are used.
That seems to be the origin of the bug here. It will also make it harder to see that the program can easily be much more efficient.
If you really have to make flowcharts, i would recommend to make and test a correct program first, and then produce a flowchart. It should be easy enough to learn how to put a for, while or if into a flowchart. The flowchart will be no help with making a program unless you want to avoid any higher level code structures.
I don't know ho to write a program we didnt learn about it..But I see your point in general and you are right. Maybe yeah it was the problem. So now I have to create a flowchart to calculate a gcd for two positive integers.
Our flowcharts are rather simple things..thats how we are doing in class..
