Mass and weight differences on earth
At the Earth's center, the mass of an object remains constant, while its weight decreases as it approaches the center. If a rock is dropped into a hole leading to the Earth's center, it will experience a reduction in weight due to the diminishing gravitational force, which becomes zero at the center. This occurs because the gravitational forces from the Earth's mass surrounding the rock cancel each other out. The weight decreases linearly with depth, reaching zero at the center, but the mass of the rock does not change, meaning it retains the same resistance to being pushed, regardless of its weight.
mmfoley
Hello,
How do the mass and weight of an object at the Earth's center compare with their values at the Earth's surface? My textbook is pretty terrible for the non-physics major. I think they answer this question in eqations rather than plain English, so I'm having a hard time with this. Basically, I'm trying to figure out if I dug a hole down to the center of the Earth and dropped a rock down the hole, how would its mass and weight change from the surface of the Earth to the center of the earth.
Thanks!
mmfoley
The mass will remain constant but as the rock fell toward the center of the earth, it's weight would decrease. At the center of the earth, the rock would be weightless. The net gravitational force would be zero since the Earth's mass is surrounding the rock. The gravitational force of the Earth on one side of the rock will cancel out the force on the other side.
note: actually the rock would be weightless at the gravitational center of the Earth which doesn't exactly coincide with its geometrical center due to irregularities in the density of the earth. It's probably pretty close so for a simplified case it's OK to assume that the geometrical and gravitational centers are the same.
Originally posted by mmfoley
... I'm trying to figure out if I dug a hole down to the center of the Earth and dropped a rock down the hole, how would its mass and weight change from the surface of the Earth to the center of the earth.
The mass won't change (excluding inconsistent relativistic termonology). Weight is defined as the force of gravity exerted on an object at rest (more or less). Approximating the Earth as a perfect solid sphere, the wieght would decrease linearly with depth until it reached zero at the center (At the center of the earth, there is no pull of gravity in this model. The weight would be directly proportional to the distance from the center).
The significance of the mass not changing is that the object would remain just as difficult to push, even though its weigth would decrease.
thank you
thank you both!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
