Tank Mass Balance Calculation for Designing w/ Automatic Float Switch
The discussion focuses on the mass balance calculation for a tank design featuring an automatic float switch that activates a valve to fill the tank when the water level drops. The key equation used is A(dh/dt) = Qin - Qout, where A represents the tank area, h is the tank height, and Q denotes the flow rate. The user successfully rearranged the equation to derive h(t) = [(Qin-Qout)/A] * Δt, confirming that the units are consistent and yield the expected measurement in feet. This indicates a correct approach to modeling the tank's behavior under the specified conditions.
  • Understanding of mass balance equations in fluid dynamics
  • Familiarity with tank design principles and flow rate calculations
  • Knowledge of integration techniques in calculus
  • Basic concepts of automatic float switch mechanisms
  • Research advanced tank design methodologies and simulations
  • Learn about flow rate measurement techniques and their applications
  • Explore the impact of varying discharge rates on tank performance
  • Investigate control systems for automatic float switches in fluid management
Engineers and designers involved in fluid dynamics, tank design, and automated systems, particularly those focusing on mass balance calculations and flow management in industrial applications.
mudweez0009
I'll be using a mass balance calc for a tank design at work. We are designing a tank that has an automatic float switch on it, attached to a valve which will start filling the tank when the water level drops below a certain point. This tank is intended to drain quickly (flow rate not known at this time), but the fill rate will not be as large as the discharge rate. I want to have a representative model of the tank so we can ensure it will function properly.
Anyway, I just want to double check to see if I did this correctly. I think I did, as its relatively simple, but another set of eyes never hurts.
What I have done so far:
I'll skip the intro equation sorting, and get to the generic equation below:
Where,
A = Tank area
h = tank height
Q = flow rate
My attempt:
I moved "A" and "dt" to the right-hand side, and got:
dh = (Qin - Qout)/A * dt
I then integrated to get h(t):
I think this would be correct, as the units leave me with "ft"
Q (ft3/s) * 1/A (1/ft2) * Δt (s) = ft.
So far, so good ! Carry on !
  • · Replies 24 ·
