Umaxo
- 51
- 12
Hi,
i got little confused after this conversation
There was also this conversation:
So i want to clear the confusion.
As was pointed out to me, in STR mass is defined as m2=E2 - p2, which can be done for all objects. But I was taught, that in GR there are, in general, some problems.
I know it can be done by computation/measurement of 4-momentum in asymptoticly flat region and then using STR definition of mass, but not all solutions of einstein equations are asymptoticly flat.
So are there really no dificulties with mass in GR as is Mister T saying? He says, that "the mass of a macroscopic object it includes the energies of the particles that make up that object", but again i was taught there is problem with this approach, because there is no gravitational energy in GR, so there is no contribution from gravity to overall mass if one tries to compute it this way. However, gravitation has its inprint on the mass of the object.
And about the question wheter there is indeed only one mass in modern physics - one could imagine observer who doesn't have acces to informations from asymptoticly flat region and has only acces to information near some object where there is "wild" curvature. But he still wants to somehow measure properties of the object, so different definition of mass would be needed for him. So are there some different kinds of masses in GR (i guess they should reduce to same number if pu can be appropriately defined), or indeed there is only definition m2=pupu?
Thanks for all the future replies:)
Mister T said:It is best to adopt the modern terminology and refer to it simply as the mass. There is no other kind of mass used in the modern lexicon so there is no need to preface it with "rest" to distinguish it. The history of relativistic physics gave rise to terms that we no longer use: relativistic mass, transverse mass (which is identical to relativistic mass), and longitudinal mass.
Umaxo said:Yes i know, i am not using the other masses and neither did i come in (serious) contact with them in college (i was just confused how the concept comes into being, without realising it since it doesn't influence any of the calculations i have seen or did). But in my university everyone says "rest mass" - i guess it is just an habbit, or to make it clearer what is meant. I mean, in GR there are more definitions of mass, so i guess it is not that bad idea to use "full name" for them.
in https://www.physicsforums.com/threads/some-questions-about-light-and-relativity.918094/page-2Mister T said:In the standard terminology of physics there is only one kind of mass, the ordinary mass. It just causes confusion to call it the rest mass.
Umaxo said:Hi,
I don't want to spam the topic, so i write directly to you.
You wrote: "In the standard terminology of physics there is only one kind of mass, the ordinary mass. It just causes confusion to call it the rest mass.".
Isnt this valid only for test particles (and som other special cases)? If you want to speak about mass of macroscopic objects, in general you should run into dificulties as i understand.
Mister T said:No difficulties. When you measure the mass of a macroscopic object it includes the energies of the particles that make up that object. In other words, the mass of that object is not equal to the sum of the masses of those constituent particles. This is the lesson of the Einstein mass-energy equivalence.
