Mass falling in Earth's Gravity help
9 replies · 4K views
kraigandrews
A particle falls in Earth's gravity. The force of air resistance is F = −αv v where v is the velocity, v is the speed, and α is a constant. (The direction of the force is opposite to the velocity, and the magnitude of the force is αv^2.) If the terminal speed is 20.2 m/s and the mass is 2.6 kg, determine the constant α.
F=mdv/dt
m(dv/dt)=mg-aplhav
thus v(t)=(mg/aplha)(1-e^(-(alpha/m)t))
so aplha if I am correct should be (mg/Vterminal)=1.263, however I am not sure of the units for this. My guess would be kg/s however my homework programs says that is incorrect, and also I feel I may have neglected the [/B]v[/B] and the magnitude of the opposing force causing a wrong answer.
If someone could shed some light on this it is greatly appreciated.
From your formula it seems that you need to use
F=-αv2 so you'd have
ma = mg - αv2
If that's the case then what does the F=-αv mean? To me, the question is pretty confusing as far as what goes where.
At terminal velocity the velocity is constant. So the acceleration must be nil. What can you say about the forces acting in that case?
it would be dv/dt=a=0 thus the net forces are balanced, I guess my confusion is what is the question asking for as the resistive force F=-αv or F=-αv^2?
Well, I'd go with the magnitude of the resistive force and make the appropriate assumption about its direction for a body falling straight down :wink:
I do find the notation vv a bit odd. I mean, why not v with a unit vector for direction? Maybe it's just me...:smile:
The magnitude of F = −αv v, where the second v is a vector is -av^2. And it points in a direction opposite to the vector v if a is a positive constant.
I think the problem statement says the magnitude is av^2. So I don't think they mean the vector v to be a unit. As you said.
Hi Dick, That was my point; it wasn't a (magnitude)*(unit-vector) construct, but rather a magnitude*vector (vv as opposed to v2u).
On reflection, I can see the utility of doing it this way when the magnitude you want is the square of the vector. vv rather than v2*(v/v).
Hi gneill, yeah, I realized what you meant after I posted. Nothing wrong with the unit vector notation either. At least it makes the velocity dependence clearer than it was to kraigandrews.
