Mass of a body when Acceleration is 0 and Force is 0.
The discussion revolves around the concept of mass in the context of Newton's second law, specifically when both force and acceleration are zero. Participants explore the implications of this scenario, questioning the nature of mass and its measurement under these conditions.
  • Some participants assert that if force and acceleration are both zero, the mass of the body cannot be uniquely determined, as division by zero is problematic.
  • Others suggest that mass can be treated as a variable that could take any numerical value in this scenario, highlighting the ambiguity in defining mass without force or acceleration.
  • A participant introduces the idea of limits from calculus, proposing that mass can be understood through the gradient of a force-acceleration graph, even when force approaches zero.
  • There is a philosophical debate about whether mass is a fundamental property or merely a measured quantity that can change based on observation.
  • Some participants argue that mass should be considered a constant property, while others contend that it may vary depending on the frame of reference, particularly in the context of general relativity.
  • One participant challenges the notion that mass can change between observations, asserting that mass is a fundamental property that does not fluctuate.
  • Another participant emphasizes the importance of mathematical reasoning in addressing the question, suggesting that qualitative explanations may not be necessary.
Participants do not reach a consensus on the nature of mass when both force and acceleration are zero. Multiple competing views remain regarding whether mass is a fundamental property or a variable dependent on context and observation.
The discussion includes unresolved mathematical implications, particularly regarding division by zero and the interpretation of mass in different frames of reference. The philosophical aspects of mass and its measurement are also not fully resolved.
Ankit Mathur
We know that Force= Mass x Acceleration. When the force applied on a body is 0 the accelaration produced in the body is also 0. (F=m a). So, what will be the mass of a body on which no force is applied and no acceleration is produced?
[ mentor note: post moved from New Member Introductions forum ]
Hi Ankit Mathur. :welcome:
What are your thoughts on this conundrum?
0 cannot be divided by 0. So I think from now val. mass shold be given in the numericlas of physics.
don't overthink it ... get back to basics
how about googling ... what is mass? and see what you come up with
any thing you don't quite understand, ask a question :smile:
Why not try some values? Does m of 1kg work in your equation?
What about 2 kg? Does 0.1 kg satisfy your equation?
Try x kg, where x is any value > 0.
A.M.
If you mean that mass can only be measured when there is an acceleration (F=ma) you are right, but there is no problem. Consider a massive particle at the centre of gravity of a massive system. The particle itself experiences no net force, no acceleration, but it exerts a net force on (let's say) every other element of the system. Of course, if you can imagine a universe containing only one point particle, the concept of mass would be meaningless.
Ok
If one is used to the ideas in Calculus then the 'Limit as δx approaches zero' being the gradient of a curve will be a familiar idea. The Limit for f=ma, as f approaches zero will give the value of mass. i.e. your force can be a small as you like. (And the curve is, of course, a straight line in tis case.)
In words: When we look at anybody accelerating in response to an external force, we find that F=ka, and we call that constant of proportionality "mass". But A.M. wanted to know what happens if there is no F, no a. I think that you are ignoring the problem (and what has calculus fot to do with it?) The problem is real, and there are two schools of thought in the philosophy of science. Some (count me in) hold that mass is just the measured quantity k - a number we find (or could find) by observation of acceleration in response to a force. Others hold that mass is a stuff that exists and persists between observations. I think such a view is inconsistent with QM.
It has everything to do with it. The Mass is the gradient of the f/a graph (at least that's one way of looking at it), which is where the Calculus comes into it and it also takes care of the 'zero force' situation by introducing the idea of a limit for that particular relationship. Whether or not you choose to believe that Mass is any more real than other physical quantities, it can still be regarded as a ratio and it just depends where you happen to be starting from.
My mathematical response to the OP has my excellent School (and further) Maths tuition to blame. I have never found Maths to do anything but to help to add to my personal feeling of understanding of the Physical world.
That doesn't look right to me. Mass is a fundamental property, not something that can change between observations, like the position of a particle or the orientation of its spin.
I'm afraid you got that wrong. Gradient is tan theta. It is only when there is no theta, no unique angle, that we use differential calculus - we extend a property of straight lines to curved lines by a clever mathematical argument. You are suggesting the opposite: that we can only discover the properties of straight lines by finding the limiting cases of more fundamental rules for curved lines. Don't blame your teachers - you learned tangents long before you learned calculus - necessarily so.
You only need to explore the mathematical implications of the question you are describing to get the answer - no qualitative explanation is required.
There are two cases of division by 0 which are forbidden in math:
1)##\frac {x}{0}## where x is non-zero
2) ##\frac {0}{0}##
The first case is disallowed because there is no number which when multiplied by 0 gives you a non-zero number. (There is no answer)
The second case is disallowed because every number gives you 0 when it is multiplied by 0, so the set of all numbers is the solution. Since there is no unique solution to this problem, this kind of expression is usually considered meaningless.
So there is your answer - the mass can take any numerical value that you care to specify in your scenario. It is impossible to determine a unique value for the mass with the information that has been provided.
The short answer is that we don't know any properties to be fundamental. Mass is more problematic than most. In GR mass depends on your frame of reference, and changes if you are in a changing frame of reference. But the big issue is not whether mass changes from one observation to another, but whether there is any meaning to the word for an unobserved particle. Don't get me wrong - in my everyday life I am perfectly happy that the kilo of flour on my shelf will persist until needed, as will the standard kilogram ingot in Paris (I think). But that property is is not so very different from the properties of solidity and continuousness which break down into something entirely different and more fundamental.
This is not true.
PWiz said:
This is not true.
I hope you mean that the masses of objects sharing the observer's frame of reference behave in the everyday way. That would be true, but irrelevant to my point. Two identical bodies making a close approach at relativistic velocities will each measure the mass of the other as greater than their own. If you believe there is some god-like perspective from which absolutely true values for mass can be observed, you have missed the point of relativity. (I could have just as easily included Special Relativity - but I didn't want to get into the special case of the "invariant mass" of an isolated system.)
Sorry, that was unfair. Do blame your teachers. They didn't sufficiently emphasise that dy/dx is not actuially a gradient. It's not actually a fraction.
On the contrary, I would be forced to advise you to look at the definition of mass in relativity again.
Non-relativistically, mass is defined as a measure of inertia, which tells us how much matter is present in an object. This definition starts to break down is SR, as the coordinate acceleration of an object approaching relativistic velocities starts to differ from the proper acceleration experienced by the accelerating object (the Newtonian acceleration ##a## is related to the proper acceleration of ##\alpha## by the relation ##\alpha={ \gamma }^3 a## , and you can clearly see that the coordinate acceleration decreases as the relative velocity between the frames increases even if the proper acceleration stays constant), so the familiar ##F=ma## cannot readily be used (which is the non-relativistic definition).
The relativistic mass was introduced to restore the "classical" version of many equations, primarily the linear momentum expression ##p=\gamma m_0 v=mv## where ##m=\gamma m_0##. This is VERY misleading, so much so that the mentors have set up an entire FAQ thread on it. Whether the observer is moving or not wrt to the object will make 0 physical difference to the actual intrinisic structure of the object, and its mass in its rest frame will remain unchanged. You're using "relativistic mass" to describe "mass," which is very different from the usual interpretation of mass meaning "invariant mass."
I also don't get why you mentioned GR in your post when this is clearly an SR issue - we are not concerned with intrinsic spacetime curvature over here.
And by the way, I have not made any allusions to a "true" reference frame in my previous post.
OK, this thread seems to have gone far off into deep water with no navigational aids...
It is closed.
  • · Replies 29 ·
  • · Replies 17 ·
