Calculating the Mass of a Half Ball with Given Density δ(x, y, z)
The discussion focuses on calculating the mass of a half-ball defined by the inequality x² + y² + z² ≤ 4 and z ≥ 0, with a density function δ(x, y, z) = (x² + y² + z²)^(1/2). Participants emphasize the need to use spherical coordinates for this problem, as the density varies with the radius. The correct approach involves setting up a triple integral in spherical coordinates, utilizing the volume element dV = ρ² sin(θ) dr dφ dθ, to account for the mass calculation accurately.
  • Understanding of spherical coordinates in calculus
  • Familiarity with triple integrals and volume elements
  • Knowledge of density functions and mass calculations
  • Experience with parametrization of surfaces
  • Study the derivation and application of the volume element in spherical coordinates
  • Learn how to set up and evaluate triple integrals for mass calculations
  • Explore the differences between mass calculations for solid objects versus shells
  • Practice problems involving variable density functions in three-dimensional space
Students in calculus or physics courses, mathematicians dealing with integrals, and anyone interested in understanding mass calculations in three-dimensional geometry.
RaulTheUCSCSlug
If the density of the half-ball x ^2 + y ^2 + z ^2 ≤ 4 ; z ≥ 0 is given by δ(x, y, z) = ( x^ 2 + y^ 2 + z ^2)^(1/2) find its mass.
∫∫F⋅ds
∫∫FoΦ(u,v)||Tu,Tv||dudv
∫∫FoΦ(u,v)⋅(Tu,Tv)dudv
For the last problem I was asked to find the density of the shell and used the equation
∫∫FoΦ(u,v)||Tu,Tv||dudv, but now I don't know if I use the same thing or not. I know how to parametrize it and know that it will be a ball of radius 2 but don't know if I use the same equation or not.
No idea what your T stand for. Normally mass is ##\int \rho \, dV## and I'm missing that relevant equation...
Tu stands for Φ(u,v) derivative with respect to u and Tv is Φ(u,v) with respect to v.
What I did in the previous problem was parameterize the surface, but that was asking for mass of shell, now it is mass of ball. So am I supposed to use volume then divide by the density? ? ?
Displaces the unknown to u and v. Why not use the simple equation ?
Oops it's supposed to be x^2+y^2+z^2=/< 4, so it would be best to convert to spherical coordinates.
Yep.
doesnt answer my question though.
That was a typ-o from copying and pasting, I am still stuck on what to do...
This problem is a natural for spherical coordinates, as the density varies with the radius, and the object is half a sphere.
What does not answer which question?
Yes, I know, there was a typo before, but the typo is no longer there, I already switched to spherical coordinates, hence the equation that I am using since I am perimeterizing.
BvU said:
Yep.
Okay, I know to use spherical coordinates. I just am not sure which integral to use. That is my confusion.
How does this question differ from when they ask for the mass of a spherical shell. Because I can do the shell fine, but I just don't know how it jumps to volume... or when the object is full.
It wouldn't be any of the three you wrote in your relevant equations. As BvU wrote, the basic integral is ##\int \rho dV##, which in this problem turns out to be a triple integral in spherical coordinates. For the shape of the object and the density function, I think you might be able to get away with a double integral, although I haven't set up the problem.
In any case, the typical volume element would be a hemispherical shell, sort of like a layer in an onion. At each point in a given shell, all the points are the same distance from the origin, hence the density is the same for each point.
so triple integral from the bounds being the same as if i was finding half a sphere (obviously) times the Jacobian integrated with the density function in terms of spherical coordinates. That would be this equations ∫∫FoΦ(u,v)||Tu,Tv||dudv as this part ∫∫FoΦ(u,v)(((((||Tu,Tv||)))))dudv is the Jacobian.
So I'm not sure why you are all saying that the equations are wrong or unfamiliar? But if this is the case, which I do not think, where do we account for the change of radius from 0 to 2. We wouldn't account for it at all.
There is no Jacobian. And why don't you start writing out ##dV## and ##\rho## ( your ##\delta## ) in spherical coordinates ? Who knows, the angular part can be integrated easily and you are left with one simple integral in ##r##...
So just take the volume integral with the density formula and that will account for the change in density. But why is there no jacobian if we are changing coordinate systems we must account for this somehow...
You aren't really changing coordinate systems, since you aren't starting from an iterated integral ##\int \int \int f(x, y, z) dx~dy~dz##, and then changing to a different integral with a different volume element.
What's the formula for density?
The density formula you are given is mass per unit volume. For a hemispherical shell whose volume is ##\Delta V##, the mass of that volume element is ##\Delta m = \rho \Delta V##.
Because you keep referring to a two-dimensional integral whereas this is a three-dimensional problem.
The volume element in spherical coordinates is ##dV = \rho^2 \sin\theta\,dr\,d\phi\,d\theta##. If you're using spherical coordinates, you usually start here. You don't bother rederiving the factor of ##\rho^2 \sin\theta##, which comes from the Jacobian when you switch from cartesian to spherical coordinates.
Oh okay, this clarified it for me, redid the problem and got it correctly, thank you! :woot:
