Mass Tipping a Plank: Independent & Dependent Variables + Data
  • Thread starter Thread starter uniquegirl
    Mass
The discussion centers on identifying independent and dependent variables in an experiment involving tipping a ruler with coins. The independent variable is the mass of the coins (##m##), while the dependent variable is the tipping distance (##d##). Participants clarified that the mass should be plotted against the distance to analyze the relationship, which can be predicted based on physics principles. The experiment aims to determine the nature of the relationship between mass and tipping distance.
  • Understanding of independent and dependent variables
  • Basic knowledge of physics principles related to mass and force
  • Ability to conduct experiments and collect data
  • Familiarity with graphing techniques for data analysis
  • Learn how to graph independent vs. dependent variables effectively
  • Explore the principles of torque and balance in physics
  • Investigate different types of relationships (e.g., linear, inverse, quadratic) in experimental data
  • Study methods for analyzing experimental results and drawing conclusions
Students conducting physics experiments, educators teaching scientific methods, and anyone interested in understanding the relationship between mass and tipping points in physical systems.
uniquegirl
Carry out your own investigation into the relationship between the mass of an object on a plank (𝑚𝑚) and the distance from the fulcrum (𝑑𝑑) at which it will cause the plank to tip.
You will use a ruler to model the plank and a pile of quarters (6) to model the mass of the cyclist. Set up the ruler so that the coin is just on the point of tipping the ruler. Once the ruler is positioned, do not move it. Vary the mass of the pile of coins (by adding more coins). Move the coins (not the ruler) to find the new tipping point.
https://www.physicsforums.com/attachments/1567809385305-png.249313/
Can someone tell me what the Independent and Dependent variable is? And what is the data I'm supposed to collect? Is it the distance when the coins tip or is it the mass of the coins? Please help!
Hi @uniquegirl and welcome to PF.
The instructions clearly state what you are supposed to do. The independent variable is the number of coins which proportional to the mass ##m## on the ruler. The dependent variable is the tipping distance ##d##. You are free to choose any number of coins to put on the ruler. That makes the mass ##m## the independent variable. However, once you make that choice, there is only one tipping distance ##d##. That makes ##d## the dependent variable. In other words, the value of ##d## depends on your choice of the value of ##m##.
Thank you so much for your reply. When I do my graphs, I use the mass of the coin (for example 5g) vs the distance (eg: 3cm)? Not how many coins I used right? So each time I add a new coin it increases in mass. When there are 2 coins the mass would be 10g etc.
Also what type of relationship do you think it is? (Inverse Relationship, Square Relationship etc)
It won't matter mass or number of coins ( assuming they are identical coins ), but the problem statement wants you to use mass.
That is the objective ( to determine a relationship). You should run the experiment to find out. It doesn't hurt, to make a prediction, but is should be your prediction you are testing. What model you can come up with to make your prediction is going to depend a little on how much physics you know?
To get the dependence of the
No, you plot the distance vs. mass or number of coins. What follows "vs." is the independent variable and is placed on the horizontal axis.
Thank you guys so much! you guys are life savers :)
9K
