Calculating Average Oxygen Flux in Wetted-Wall Column
The discussion focuses on calculating the average oxygen flux through the gas-liquid interface in a wetted-wall column, emphasizing the importance of considering liquid film thickness for accuracy. Participants highlight the need to assess the resistance to oxygen mass transfer, questioning whether it primarily resides on the gas or liquid side of the interface. Key parameters include the downward velocity of water, the thickness of the water layer, and the column length, which are critical for determining the average flux. The conversation underscores the significance of hydrodynamic flow equations in establishing a laminar parabolic velocity profile.
  • Understanding of wetted-wall column dynamics
  • Knowledge of oxygen mass transfer principles
  • Familiarity with hydrodynamic flow equations
  • Ability to calculate liquid film thickness
  • Research the calculation of average flux in gas-liquid systems
  • Study the effects of liquid film thickness on mass transfer rates
  • Learn about laminar flow profiles in wetted-wall columns
  • Explore methods for measuring dissolved oxygen concentration
Researchers, chemical engineers, and laboratory technicians involved in mass transfer studies, particularly those working with wetted-wall columns and oxygen flux calculations.
salih129
Dear all,
I am currently doing a lab question. I do not know how to solve a calculation question.
Question: Calculate the average flux of the oxygen through the gas-liquid interface in the wetted-wall column. Remember that a more accurate value of the average flux can be calculated by taking the the liquid film thickness into account.
BAckground: In this experiment, we have to take note of dissolved oxygen concentration at the inlet and outlet of a wetted column for changing air and water flow rates. Air will flow in from the bottom while de-oxygenated water will flow down from the top. Oxygen will diffuse into the water.
I would appreciate any help. Thanks.
salih129 said:
Dear all,
Hi Salih129. Welcome to Physics Forums!
Where do you think the main resistance to oxygen mass transfer is going to reside (a) on the gas side of the interface or (b) on the liquid side of the interface?
Assume you have water moving down the wall with a laminar parabolic velocity profile, as determined by solving the hydrodynamic flow equation. How thick is the layer of water on the wall in your application? What is the downward velocity of the water at the interface, and how long is the column? How long does it take for the water at the interface travel down the length of the column?
Chet
