Mass, Volume, Density work with a Sphere
11 replies · 5K views · last reply
jdsconsumer
A spherical shell has an outside radius of 2.75 cm and an inside radius of a. The shell wall has uniform thickness and is made of a material with density 4.59 g/cm3. The space inside the shell is filled with a liquid having a density of 1.00 g/cm3. (a) Find the mass m of the sphere, including its contents, as a function of a.
Answer that I got much help on from previous helpers: m = 399.33 - 4.79 pi ( a^3 ) grams
(b) For what value of a does m have its maximum possible value?
(c) What is this maximum mass?
(d) Explain whether the value from part (c) agrees with the result of a direct calculation of the mass of a solid sphere of uniform density made of the same material as the shell.
I am now on part (b). So am I trying to find the maximum of that function of "a"?
Is there any other
equation between a and m If you can tell me then I can help you
According to the equation, if you increase a what happens to m?
uhm, if a increases it looks like m will get smaller, right?
ArmanCham said:
Is there any other
No other equation that is given to me. I think we have to formulate our own...
Right. And if you decrease a?
Then m would get larger.
jbriggs444 said:
So if you want to maximize m, what must you do with a?
make it smaller and smaller until I can't make it any smaller? So if I reduced it to 0, the minimum it's radius could be, then m couldn't get any larger at that point. At least from the decrement of a.
jbriggs444 said:
Yup. There you go.
You are awesome, I love how you did that for me! Incredible!
Thank you, jbriggs444!
grrr, why was that so hard for me to talk through on my own?! That is awesome! I feel so much better now!
