Mass vs Compression: How Do They Exert Pressure?
  • Context: High School
  • Thread starter Thread starter D9 XTC
    Compression Mass
This discussion clarifies the distinction between mass and compression in terms of pressure exertion. It establishes that weight is a force, while pressure is defined as force per area, typically measured in pounds per square inch (psi). The example provided illustrates that a 100 lb weight and a bolt exerting 100 lbs of pressure can be compared by analyzing the force applied over the area. The conclusion emphasizes that despite different applications of force, the resulting pressure can be similar if the area of application is taken into account.
  • Understanding of basic physics concepts such as force and pressure.
  • Familiarity with units of measurement, specifically pounds and psi.
  • Knowledge of tensile loads and gravitational forces.
  • Basic comprehension of how area affects pressure calculations.
  • Research the relationship between force, area, and pressure in fluid mechanics.
  • Explore the differences between static and dynamic pressure in various materials.
  • Learn about the applications of pressure in engineering, particularly in structural analysis.
  • Investigate the effects of pressure distribution in different loading scenarios.
Students of physics, engineers, and anyone interested in understanding the principles of pressure and force in mechanical systems.
D9 XTC
I'm curious about how mass and compression differ in how they exert pressure. For example:
You have a piece of wood. On the woods sits a 100lb weight. Somewhere else on the wood is a bolt going through it with a nut on the other side. This bolt and nut is tightened so that it exerts 100lbs of pressure just like the 100lb weight is doing.
Am I right to think that there are just multiple was of exerting pressure?
Weight is a Force, while pressure is Force per Area. This means that 100 lbs is not a pressure at all. The most common unit in the US would be lbs/in^2 (pounds per square inch) or psi (don't worry about psi, psia, or psig yet).
Ignoring how the force is applied (gravitation vs tensile load) all you need to do is compare the forces to the areas. Obviously for the bolt, the area is quite small. This means for an equivalent pressure to the one the 100 lb weight applies, there probably needs to be a smaller force.
Also ignoring where the forces are located on the piece of wood, you could for the most part consider these two pressure similar. If the piece of wood were supported directly underneath the weight, then the two cases would be similar enough to be considered equal for this simple question.
  • · Replies 23 ·
  • · Replies 28 ·
